hvlp painters
Old Apr 8, 2003 | 07:00 PM
Gwilkrrs's Avatar
Gwilkrrs
hvlp painters
anyone use the hvlp sprayers? do they work? are they worth $600? ive never painted before other then spray bomb jobs and am looking into these. thanks
Old Apr 8, 2003 | 08:29 PM
Huntsman's Avatar
Huntsman
hvlp painters
I have the HVLP 'porter-cable' brand from Lowe’s and have not been real happy with it but you get what you pay for, most of the time. I have since purchased a DeVilbiss 'Plus' which is not marketed as a true HVLP but close...almost 65% transfer efficiency, which is required to be classed as a true HVLP gun. In short, it is a great gun at around $300. I don't see how any gun can lay out a smoother finish at any price. No comparison to the Lowe’s gun which is now the primer gun.
Old Apr 8, 2003 | 11:08 PM
cid's Avatar
cid
hvlp painters
I have 2 Devilbiss GTI Millenium Series HVLP guns. One is set up for base and the other clear. The guns are around 500 each. I have no complaints. I have found that parts are easy to find and cheaper than the Sata brand. I have found that if yoiu have them set up properly you get superior atomization and even overlap. This is important when spraying high metallic pearl finishes.
Old Apr 8, 2003 | 11:09 PM
cid's Avatar
cid
hvlp painters
PS I do have a Sata but now use it as a primer surfacer gun. Im not crazy about the feel or weight of this gun. I do like the placement of the air and fan controls vs the GTI's though.
Old Apr 9, 2003 | 07:24 PM
Gwilkrrs's Avatar
Gwilkrrs
hvlp painters
that sounds good these are from tp tools and are 500$. ill check it out. how much is the lowes prier set-up. am i correct that i will not need an air compressor for the hvlp?
Old Apr 9, 2003 | 08:16 PM
Huntsman's Avatar
Huntsman
hvlp painters
The HVLP does require an air compressor and a LOT of air, from 11-15 CFM depending on the model.
Old Apr 11, 2003 | 10:14 PM
cid's Avatar
cid
hvlp painters
Thats right, LOTS of air. The folks selling the gun should talk about volume. The HVLP guns take far more than a suction fed gun. For this reason you need to use the hose diameters AND certain couplings (both need to be larger).
Old Apr 13, 2003 | 05:30 PM
Gwilkrrs's Avatar
Gwilkrrs
hvlp painters
tp tool catalog has this hvlp unit that doesnt use a compressor, it has a turbine built into the cabinet. any thoughts on these? they have 1 for 500 and 1 for 600.
Old Apr 21, 2003 | 02:21 PM
78bigbronco's Avatar
78bigbronco
hvlp painters
Hello, I am a beginner to bodywork and painting, and dont have a job currently either so $500 paint guns are out of the question. I am doing my first 4x4 buildup too. I am NOT trying to do a pro job as I know it will take alot of practice to be profficient at this, infact thats what this truck is, my experimental truck. My bronco is currently grey with paint peeling, I am just trying to make it look a little better considering I live in a nice neghborhood. I want to do it right (do all the body work and sanding, use good primer and paint with many thin coats, clear coat, etc)... I am just not concerned about it being 100% perfect. A couple of runs, orange peel, etc., as long as it looks good from across the street I will be happy
So, I have looked at HVLP systems and currently have the one from harbor fright tools on raincheck for like $55. It is a complete stand alone system with built in 'turbine' plus the very much large hoses. i was just wondering if it would be worth $55 just for atleast the primer. I figure if it really is as efficient as it says it will save $55 in paint in just a couple coats. Maybe even use it for the base coat of paint, but then top coat it and clear coat it with a high pressure gun? I got a $15 one of those guns to but I think for the topcoats I will buy a better one... like the best one at harbor fright might run $75-100.
So for practice painting and to make my peeling grey painted truck look a little better, will these cheap guns perform good enough? otherwise it stays peely grey LOL!
hojolabo
Paint & Bodywork
Apr 5, 2008 11:41 PM
kevin.ford-trucks
Paint & Bodywork
15
Jan 4, 2008 05:51 PM
the_hetz
Paint & Bodywork
Oct 24, 2007 06:13 PM
hobo.labo
Paint & Bodywork
May 21, 2006 08:44 AM
darkman
Paint & Bodywork
Nov 5, 2003 12:25 PM
