4x4 conversion
Old Aug 12, 2005 | 07:43 PM
scottddove's Avatar
scottddove
4x2 to a 4x4 1986 ford lariat
<HR style="COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message -->
Hi all I am new here got a question for anyone who may want to try and answer. I have bought a 86 ford lariat 4x2 it is in mint condition only problem is I have to have a 4x4. This truck has a 5.0 EFI overdrive transmission. The question is this is it possible to buy a donar truck or bronco and swap out the nessasary parts to make my truck a 4x4 I am very machaically inclined and have a shop with all the nessasary tools to do this I just wanted some advise from some other poeople who may have had some experience in this area and maybe some do's and don't's.I have a donor 1986 bronco with the same motor 5.0 efi and a overdrive transmission. This leads to another question can you just bolt on the transfer case to my transmission in my 4x2 or are they diffrent in a 4x4 and this will mean I will have to change the whole tranny. thanks for the help Scott Dove.
Old Aug 12, 2005 | 07:48 PM
oldhalftons's Avatar
oldhalftons
if you have a 80-96 4x4 1/2-ton/bronco parts truck, it is a simple matter of swapping parts.
you will need to put the 4x4 transmission in.
Old Aug 12, 2005 | 07:49 PM
andym's Avatar
andym
Check out the tech article section. There's a step by step on how to do it. It's pretty easy once you have the donor.
Old Aug 12, 2005 | 08:31 PM
scottddove's Avatar
scottddove
thanks for the replys andym can you help me find the location of the article you are talking about I cant seem to locate it. thanx scott
Old Aug 12, 2005 | 08:42 PM
fordborn's Avatar
fordborn
"scottddove" welcome to the site. Hope you will enjoy your stay here and keep using us for information, advice and fun.
Try this link for your question: https://www.ford-trucks.com/article/..._F100150s.html
Old Aug 12, 2005 | 08:43 PM
brokebronco's Avatar
brokebronco
Here you go.
On edit: I guess Rollie was faster on the draw than me.
Chris
Old Aug 12, 2005 | 08:53 PM
fordborn's Avatar
fordborn
Good work Chris, just beat you by 1 minute . He should be able to get to it anyway.
Old Aug 12, 2005 | 11:07 PM
brokebronco
You had to get up at the *crack* of dawn to beat me to the answer.
Chris
Old Aug 12, 2005 | 11:14 PM
fordborn's Avatar
fordborn
Ok, just had to throw in a crack comment huh.
Old Aug 13, 2005 | 10:01 AM
Lee Lichterman's Avatar
Lee Lichterman
Start knocking out the rivots now and replacing them with Grade 8 Bolts. I did this conversion on my truck and the rivets are the worst part of the whole job.
Chances are that the donor truck, if you are lucky, will have dual shock towers so you will want to swap those in the front. In the rear, the 2WD has 2 1/2" leaf springs while the 4x4 has 3" leaf springs so you will need to take the leaf shackle brackets off and swap them as well. Basically you are looking at removing a ton of rivets for the donor and the receiver trucks.
There are many methods for removing these and each person has their own favorites though I found that certain locations seemed to favor different methods. A good air chisel helps for most of them. On some, grinding the head flat, then drilling worked well. On some I just used a sawz all, especially on the ones I didn't care about scratching up.
The job itself isn't hard or take long at all. The rivets will be the slow part. I tried to post my notes on doing it but it is too long. I will post it in sections for you in the next 2 posts. One of these days, I will get my pictures of the project posted. I'll put it on my to do list for today.
Good Luck,
Lee
Old Aug 13, 2005 | 10:07 AM
Lee Lichterman
Swap over is pretty straight forward. I spent as much time looking for the right size socket as I did doing the actual work.
Also, everything you hear about getting off the shock/spring buckets and leaf spring shackles is true. It is by far the hardest part of the whole project. I was so sick and tired of grinding and am about deaf from the air hammer and I could barely lift my arms by the time I was done.
For anyone wanting to do this project, I would highly recommend that you start the rivet removal process early and replace them with bolts on your truck so that you don't have to do twice as many when the time comes. Also, this will allow time to remove rust and paint so it can dry while working on the donor vehicle. I was surprised at how my rust free vehicle had rust trying to start behind the front shock buckets where the two pieces of metal came together at the frame. This area really needs to be treated before re-assembly.
Anyway, tricks I have learned from doing this.........
After getting rid of all those darn rivots, they are replaced with 7/16 grade 8 Bolts and they fit perfect. Use Red thread lock on them as well. It helps stop them from rusting together later and will also keep them from vibrating loose.
It is much easier to take off the TTB pivots as soon as possible and leave the radius arms, shocks and springs hooked up otherwise they twist and get stuck. I wish I knew this when I was taking apart the donor vehicle. I didn't figure it out until I was taking my own truck apart and realized how much easier it went. Dropping the 2WD axle only took about an hour, the 4x4 was about 6 hours ( I have air tools, pressure washed everything first and then soaked it in breakfree ). Grinding the shock/spring buckets took about 6 hours. It was a REALLY big pain the rear.
I first took off the tires, then the sway bar, then the TTB attachment points at the engine support crossbrace, the brake lines, then the shocks, the radius arms, then the springs. Support each wheel when doing the shocks and radius arms, then lower and do the springs from the top 1/2 inch bolt.
Radius Arms are 29 MM nuts or an 1 1/8 will work
Bolts on TTB arms are 18mm while nuts on the back of them are 21mm
Sway bar has 18mm bolts with 15mm nuts on the back where it hooks to the frame. The nuts at the end links are 18mm.
The spring tower attachments are 1/2 inch at the top retainer.
Lower spring “keeper” is 1 1/8 and a 12” plus two 6” extensions let you slip in there to get to it., put the 12” and one 6” in first to get clearance from wheel well then attach the last 6”.
The pitman arm nut was 21mm and so were most of the other drag links nuts. 18mm and 21 mm were the two sockets I used most.
Brake lines were also painful. First it wants to leak from the caliper hookup line when you are first dropping the axle. I found that the plugs that come on a new fuel filter fit in that hole perfect to stop the leak. The bolt holding it on is 9/16. Then when you get the bucket dropped and need to take off the brake line at the hard line, it is a 7/16 fitting to a 5/8 fitting.
Easiest ways I found to remove rivets was two strategies..........
...... grind the heads of the rivet until they were about 1/3 the original thickness, then I switched to the air hammer and chiseled the edges until it was cut. I then went back and ground on it one more time to get it completely flush. I then used a 1/4 punch and a 4 pound sledge to bang the rivets out. Slightly prying on the edges of the bucket helped to expose the lines of the rivet if they get lost in the grinding pattern. Some rivets came out in 5 whacks, others took hundreds and never did completely give only letting loose after all the others were removed and I pried the bucket loose. You will tear a hole in your hand as each rivet comes free and it pinches your pinky in the hole. I have as much blood on the ground as grease and oil now from each of the 12 rivets for each truck. -g- There are 6 rivets on each side, 4 on the outside and 2 on the bottom. I haven't put them back in yet but I bought 7/16 grade 8 bolts to put them back on as they looked about the same size. I will let you know if they worked or not shortly.
.......Other method was to grind just enough to get a flat surface, punch a dent at exact center then drill a small hole first, I think it was a 5/32 or 5/16 drill bit. I had a “bullet tip” that really stayed on center nicely and went through it quick. Then I went up to a 7/17 drill bit and drilled it again. The first hole really lets the larger bit fly through it. After wards, take your punch and hammer and it comes out much easier. This method is better for working around the rear shackles next to the gas tank, takes less beating with the hammer though your arms get really tired of drilling.
Again the buckets and rear spring shackles are the hardest part. Some of the rivets stayed in the frame and the frame started bending before the rivets would let loose. I had to grind those off then soak them in breakfree and bang on them the next day to get them out.
It might be obvious to most but it wasn't to me, you must swap the sway bar, the brakes etc as the 4x4 was all heavier duty stuff. My old 2WD stuff was all in better shape so I was a bit disappointed and had to replace it all again. Still ti wasn’t high priced. The drag links were both about $50 and the tie rods ends were each $22.
*********The backs of the shock/spring buckets were very rusted and so was the frame behind there. It is such a pain to take these off I don't know if it is worth it or not but I am glad I did this project as I got a chance to stop this rust before it got out of hand. Note these are California trucks so there wasn't much rust at all on either of these so it was a shock to me to see rust here. I can only imagine what it must be like on trucks where it rains more than 4 times a year. If you are doing this, I would remove the truck buckets on the truck you plan on keeping very early on and then get a good rust stopper, clean it up really good with wire brush, course grit sand paper etc, then hit it with some POR-15 or Rust Bullet and do the same to the bracket itself from the donor to stop rust in this area dead. Letting you know this up front so you can plan ahead.
Old Aug 13, 2005 | 10:08 AM
Lee Lichterman
The 7/16 grade 8 bolts were a perfect fit to replace the rivets you have to remove to swap the shock buckets. I put the bolt side out so the extra length wouldn't interfere with spring travel.
Easiest way to put everything back together was to just tack in the radius/trailing arms with just the big washer and nut, no back bushing. This holds everything in place for when you jack up each side.
Then you slowly jack the wheel up and slip in the spring and shocks. Attach those fully so they will hold things up. Two jacks are helpful so you can find a balance between the two sides to keep the springs and shocks from tilting in. I found this out the hard way. You don't need to jack the side you aren't working on all the way, just enough so that the shocks and spring will go up straight on the side you are trying to line up.
Repeat for the other side.
Hook up the pitman arm.
Now hook up the TTB attachment points. These are the hardest parts to get aligned. Just play with the two jacks and do a lot of wiggling and prying until you get the bolts in.
Connect the brakes. If you want to use that pain in the rear clip that holds the brake line to the back of the shock bucket, do it before you put the buckets in. I chose to cut it in two and make a push on clip out of it so I can change my brake lines later to longer stainless steel ones without fighting that stupid contraption.
Go back and put your bushings on the Radius arms and tighten everything up.
Throw the tires on and admire your work. You are almost done.
The sway bar is still left to do but is fairly easy. The old 2WD had a nice frame cross bracket with two holes. The 4x4 uses two brackets and each one has three holes. I just attached the sway bar to the links on the axle then swung the front up to see where it hit the frame and marked where the holes lined up and drilled those marks..
Also you have to drill some holes for the steering dampener mount.where it attaches to the crossmember. An easy three holes and it is pretty straight forward.
Now we swap the rear springs. You already pulled out all those rivets right????? Do you like rivets? OK, drill, bang, whatever your technique is, remove the spring shackle rivets.
If you have the cash, I would buy new shackles from Ford for $38 each and save on having to remove rivets from the donor vehicle. It would cut your work in half and you would have nice shiny new brackets but that is just me.
These rear springs shackles, the ones behind the wheels are a real pain to get out since the wheels throw more gunk up in there so there is more rust and frozen rivets. Also there isn’t much room to swing a hammer so it harder to get the nice full swings you got when doing the front spring buckets.
Rear leaf springs were 22mm and 24 mm bolts on the shackle to leaf bolts. Where the front shackle attaches to the frame, the top bolts are 5/8. Still haven't figured out a rhyme or reason to the mixing of socket sizes.
The rear shackle is the easiest of the two. Once you remove the head of the rivet, you can just beat the shackle off and then concentrate on getting the rivet out with repeated pounding.
As for tricks, it seemed easiest when taking off the leaf springs to unbolt the u-bolts from the rear axle first so that nothing came flying off from strain then I took off the forward bolt at the shackle then the rear. Of course I had the body jacked way up so the stress was off the springs then watched carefully as I loosened the u-bolts to gauge if I needed to raise it or lower it to get the stress at neutral.
Anyway, for anyone wanting to try this, it isn't that bad. 2 1/2 days of work and I have a 4x4 front end now. Dual shocks instead of single and some automatic lift since the 4x4 spring towers have a spacer on them. The 33s fit in nice and only rubbed slightly on the radius arms. No problem I can adjust the stops but I am putting a lift in also so will hold off on that. I only plan on driving it enough to make sure everything works OK and to let things seat in before I tighten everything down again before I start the lift kit anyway.
For anyone wanting to do this project, I would highly recommend that you start the rivet removal process early and replace them with bolts on your truck so that you don't have to do twice as many when the time comes. Also, this will allow time to remove rust and paint so it can dry while working on the donor vehicle. I will go back at some future date and strip everything down then hit it with Rust Bullet.
Have I stressed that removing the rivets is the worst part of this job. I am learning to really really really hate rivets!!!!!!!!!!!!!
PS - Removing rivets is a real pain. Have I mentioned that I hate rivets?
I have been doing the drill a hole after I cut the head off trick but I still hit a few that are stubborn. The sawz-all helped for stuff that you are going to throw away like the old 2WD brackets and towers where you don’t care if you slightly cut into it. With the sawz-all you can take the rivet head off flush then drill it and you need less drilling this way.
Part 2 – The tranny and transfer case swap
I thought I was going to be cute and remove the transmission and transfer case together to save time. The cross brace looks like it will all fit out since the cross member has a dip that corresponds to the lines of the transfer case. WRONG!
After fighting and fighting it, there is about ¼ inch clearance problem and I finally had to give in and divorce the transfer case from the transmission so just do it the way it says to and pull the transfer case then pull the tranny.
I still have not figured out how to pull the linkage loose from the tranny. It says it pops right off but mine was stuck on good so I removed the bracket from the frame, disconnected all the other linkage and removed the tranny with the linkage still on it.
The hardest part is pulling the lights and other stuff you will need to make it all look stock. The 4x4 indicator light gets it’s hot from the same circuit as the clock and some other stuff. The hot side is all in the dash and is a tan wire with redish blotches on it and splices in about 10” from the light itself. Easy stuff there. The ground that actually activates the light however is a whole other matter. This light blue wire runs from the light socket, disappears into the main wire harness that runs across the top of the dash, down the driver’s side and then runs out the firewall to a connector buried under the brake master cylinder and brake booster. From this connector, it runs along the driver’s side frame rail in a HUGE wire bundle, and exits just aft of the high-pressure fuel pump and on to the transfer case switch. I removed all of the original wire from the switch to the connector but only from the light to where it disappeared down the driver’s side edge of the dash. I then spliced the wire into my existing bundle and it now looks like it was stock.
On the first install, the transfer case to tranny seal leaked a bit so I would put sealer between there on both sides of the gasket. Even the 2WD trucks have the hump marked with an indent where the transfer case plate goes so cutting the hole was a breeze. I just drilled a couple holes then put my air nibbler in there and cut the hole out. I took the plate from teh donor vehicle in there and it was a perfect fit.
Project is now done. I have a 4x4 that looks like it was a stock from the factory deal.
Old Aug 13, 2005 | 10:56 PM
scottddove's Avatar
scottddove
4x4 conversion
thanks for all the advise on the swapout.One more question I have noticed on the bronco there is no big spacer block on the rear end like the trucks have only a thin block. question is will this work or will I need to find a block off another truck to make it all work right. Just trying to get my ducks in a row before I start this job,cant be without my truck for too long. thanks again scott dove
Old Aug 14, 2005 | 06:51 PM
fordborn's Avatar
fordborn
"scottddove" I merged your new question here with your original thread. This should keep things easier to keep track of your project.
Old Sep 17, 2005 | 10:50 PM
wranglerastro's Avatar
wranglerastro
Lee Lichterman,
I admire your dedication to your enthusiasm.
I too had wanted to swap out a really good 2wd truck that I was going to buy. I already own a 4x4. After consulting with many, I decided it was too much to do to swap.
I fixed up mine instead 4x4 instead. I got it to be mechanically excellant first. Then I worked on getting the body in good shape and rough painted it for now.
As it stands it looks pretty good and drives excellant.
Looking back I enjoyed upgrading my truck to better shape than trying to make a 2wd into 4x4.
Florida 350
35
Mar 17, 2019 09:09 AM
Meydawg51
17
Jul 17, 2016 01:16 AM
Meydawg51
Jan 15, 2016 11:29 PM
76 F250 4X4
Nov 29, 2003 07:19 PM
1ole4d
Jan 5, 2003 02:01 AM
