Please help in Identifying this Dana
Old Apr 19, 2002 | 10:34 AM
nicksort's Avatar
nicksort
I also just read that the Detroit Locker for the 61 uses the Dana 60 gears instead of the 61 thin gears.....
Old Apr 19, 2002 | 12:05 PM
DirtySideDown's Avatar
DirtySideDown
[updated:LAST EDITED ON 19-Apr-02 AT 01:10 PM (EST)]
"If anyone would like the links to any one of these sites let me know."
Nick, why don't you post the links to those sites you found. Sounds like you may be able to use the 61 after all. The price was right, so you can afford to put some money into it, which would be ok as long as you can use the 60 parts. Congrads
DSD
Old Apr 19, 2002 | 02:22 PM
nicksort's Avatar
nicksort
[updated:LAST EDITED ON 19-Apr-02 AT 03:31 PM (EST)]I hope they all work for you.....
TRACKTECH INC. This is a must see pdf file.
http://www.tractech.com/docs/LightTruckModelList.pdf
Detroit Locker
http://nationaldrivetrain.com/shopsite_sc/store/html/page23.html
CJ Project - Check out the photos of the his 61 and where he found the 61 casting Id. Also read the story about the info he found about the 61..
http://www.mudhunters.com/matt/project.htm
DTS
http://www.drivetrainspecialists.com/products.asp?catid=18&cat=DANA+61
THE REAREND
http://www.geocities.com/MotorCity/Garage/8019/rearend.html
Flatlander Racing
http://flatlanderracing.com/detroitlockers.html
TIMKEN BEARINGS
http://www.adamsdrivetrain.com/bearing_kits.htm
SORRY, I have tried to get them to show as a link and I am haveing a problem, it doesn't work for me.....
Old Apr 20, 2002 | 11:50 PM
jsworkman's Avatar
jsworkman
I've checked your bill of material numbers and I can't find them listed on any Ford, jeep, Gm, or Chrysler truck 1967 -1978 I even checked the Fords dana 61 listings for trucks from 1974-1980 if its a d61 it may be newer than 1980 but the bill of materials number should start with a 6 (601234-1)this is what th dana guy was talking about my book is a 1990 his may be newer and list models later than my book
(My book is the Spicer front & rear axles 1967-1978 Dana corp.)
Old Apr 21, 2002 | 08:07 AM
nicksort's Avatar
nicksort
I will try to check the numbers again to day....
Old Apr 21, 2002 | 08:42 AM
nicksort's Avatar
nicksort
[updated:LAST EDITED ON 21-Apr-02 AT 09:43 AM (EST)]I found the complete bill of materials number it is 608174-1
please tell me what it is.....
Old Apr 21, 2002 | 09:26 PM
jsworkman's Avatar
jsworkman
That looks to be a good number but it dosen't show up in the 1967-80 listings that I have It may be newer than 1980 give six states a call or someone elese that is a dana spicer rep and give them the number
good luck
John Workman
76 F250 Crew Cab Sb
460/C6 D60/D60
Old Apr 26, 2002 | 12:21 AM
nicksort's Avatar
nicksort
Well I did find out what it really is.
First off the BOM is 603714-1
It is a dana 61.
Not only is it not a 60 but I found out that they made 2 different Dana 61's.
If you find a Dana 61 with a 410 ratio (Yes they are out there) you can use parts from a 60.....
If you find a 61 with a 307 or 333?? ratio( Like the one I found), you have two options.
1. Sell it to a 2-wheeler for parts
or
2. Buy a big Boat cause you already have the anchor.....
I was going to narrow the dana and use it in a car.
Old Apr 26, 2002 | 10:27 AM
Jermafenser's Avatar
Jermafenser
And you wondered why you got this axle for free!
Old May 2, 2002 | 05:20 PM
onetonford's Avatar
onetonford
I guess you figured out this is a dana 61.Dana made this change to allow the use of higher gears.Normally any truck with a gear higher than 3.55 it will be a dana 61.Hope this helps.
Gregg
Old May 2, 2002 | 10:15 PM
nicksort's Avatar
nicksort
Unfortunately yes, now the question is
"should I give it away or try to modify it to accept the Dana 60 guts"
Old Oct 6, 2002 | 06:09 PM
LCOwner's Avatar
LCOwner
I hate to breath life into a depressing thread like this but what ever became of the 61?
I was recently yoked with one of these model 61 units (4.10), I was so happy when came accross this thit its 65 in WMS width and 1.65 id spindles. All I needed to do was regear and ARB it and swap to 35 spline axles and be done with it. Then I saw the '61' Thanks for the info.
Old Oct 6, 2002 | 09:04 PM
  #28
fatdaddy's Avatar
fatdaddy
burkhart3
New Member Introductions
Apr 28, 2017 08:00 PM
bullettproof77
Nov 2, 2016 10:47 AM
78 Ford F150 460
24
Aug 15, 2016 03:52 PM
sparky69
Offroad & 4x4
Dec 26, 2005 07:23 PM
easterisland
Dec 30, 2003 02:41 PM
