Clutch slave cylinder
Old 08-13-2005, 02:47 PM
scottleibing's Avatar
scottleibing
scottleibing is offline
I have a 2000 F-350 4wd, diesel, 6sp., 130000 km. My clutch pedal went right to the floor as I was about to shift from 3rd to 4th. The clutch never disengaged. I can pull it up off the floor but when I push it down it stays on the floor. I can hear the hydraulic fluid moving when I push the pedal down but the clutch stays engaged. It was working perfectly up to the time this happenned.
Old 08-13-2005, 03:07 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 08-13-2005, 05:03 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Go to Ford and get the pre-bled assembly. Something in the price range of $130.00, I think. I've never had to replace one, but I think it just quarter turns in and locks. 15 minute job.
Old 08-13-2005, 06:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Do you see fluid on the outside?
When the slave cylinder goes south the fluid drips out of the bushing.
Master cylinders may drip fluid on the outside or the fluid is just bypassing the o rings internally.
Old 08-13-2005, 08:49 PM
thestroker97's Avatar
thestroker97
thestroker97 is offline
I am not sure about the slave cylinder or master cylinder but I have experienced the same thing on my truck and I thought is was the slave cylinder but it turn out to be a spring that broke under the dash that pulls the clutch pedal back out it may not hurt to check that. I know mine would go all the way to the floor and you could take your hand and pull it back out, but still the clutch would stay engaged. hope this might help you.
Old 08-13-2005, 11:22 PM
Fis Teck's Avatar
Fis Teck
Fis Teck is offline
Check the linkage if the bushing is bad the rod to the master cylinder falls off. This makes the the peddle drop to the floor.
Old 08-14-2005, 06:49 AM
cookie88's Avatar
cookie88
cookie88 is offline
Hydraulic clutch control assembly. Part # 2C3Z-7C522-CA. List $131.10
Old 07-24-2006, 02:19 PM
vettehauler's Avatar
vettehauler
vettehauler is offline
This is a very good post....saved me a ton of work.
Old 07-24-2006, 07:01 PM
05f250fx4's Avatar
05f250fx4
05f250fx4 is offline
the connecting rod will probaly take the longest to do. everything is straight forward.
cook134
10-04-2014 06:08 PM
PNWguy
07-06-2012 09:08 PM
dspeer75
05-03-2009 01:34 PM
Truckin4life
11-24-2008 06:59 PM
PA F150 4X4
Modular V10 (6.8l)
08-06-2003 10:07 AM
Quick Reply: Clutch slave cylinder
