HELP - 95 F150 5 speed Clutch Pedal Problem
On the way to work today when shifting the clutch pedal on my 95 f150 6cyl 5spd went to the floor with a snapping sound and stayed there. I can pull it up by hand but it snaps back to the floor under pressure. I can not engage the clutch.
First, does anyone have an idea of what the problem may be?
Second, can I limp home by timing the shift points and changing gears with out the clutch without damaging anything?
Ken,
No, I do not have the "super duty, extra secret, F-150 with the 6.8 liter V-10". I caught the error after the post and reposted in the 87-95 truck forum.
I did a search on clutch and did not notice that the new thread buttom was on a "super duty, extra secret, F-150 with the 6.8 liter V-10" forum message.
By the way.
What does extra secret mean?
Sorry for the protocol violation. You can delete this one.
Larry
By the way.
Larry
Ken,
By the way.
Larry
Ken,
By the way.
Larry
I am fond of my trucks, but you were starting to worry me with the extra secret thing.
A sense of humor is a great thing to share.
If I want even worse gas milage I will check out the v10.
Pa150 4x4 coldnt find you in other forum. to . yes you can drive it home if you can speed shift without grinding have done it many times with diff. trannys sounds like the presure plate springs might be bad try to depress the pedal just far enough to disengage and see if it still does it.
marragtop
10-10-2008 08:46 AM
slow_v6_stang
08-09-2007 02:23 PM
Dalelisa_7
07-25-2007 07:59 PM
