Squeek (chirp) at shutoff
Originally Posted by ag-ford-4x4
Do all 6.0 diesels squeek when you shut them off? Mine has done it since i bought it, and i was told by several people its just the belts coming to an abrupt stop. Its not a problem, but it doesnt sound very good on a NEW truck....
Many powerstrokes and nearly all Cummins do it.
All that rotating mass coming to a sudden stop makes the belts squeak.
on
Either kill fuel or kill air. Killing fuel is usually easier - especially on our trucks.
My father in-law told me that all their fire trucks had emergency stop fuel shut offs in case the motor decided to run away for some reason. He's actually seen that happen in a fire truck that didn't have a fuel cutoff - it was a bad thing. He's also seen them get started in reverse, which must be interesting
I have 54,000 miles on my 2003 Excursion Ltd 4X4.
I have just developed the "squeek" upon shut down of the truck, but it is NOT the turbo.. but either a pully of the drive belt (I think). It doesn't do it all the time, but it does worry me??? I wonder if the high heat of the summer is causing the belt to "glaze" over and "squeek" when shutting down????
All gauges read normal and mileage and truck functions have not been compromised, so I would either think drive belt, fan clutch or something along those lines. If it happened on start-up (like the old days) it would definately be a "slipping drive belt".
Good luck,
Jeff
Good luck,
Jeff
I was commuting home along IH-30 a few months ago and had the pleasure to pass a broken-down Coca Cola truck which was suffering a runaway condition and was in the process of Valdezing oil out the stacks and all over the roadway. Apparently he either didn't have an emergency cutoff or didn't know how to use it. That was a fun cleaning job . Fortunately, I called Coke and they compensated me for time spent to remove the oil.
hmm....thats interesting. I just learned something. I had no idea that diesels had that high of compression. So since they do run on compression, the only way to kill them is to kill the fuel supply rather than just killing the spark....is that correct?
No ignition coil, no spark plugs....just glow plugs to initially heat the cylinders.
