I'm just curious for all of you that have experince dropping trucks, if you are only looking for a few inches - not a "slam" - can't you use the lowering springs and a lower profile tire? I only want about 3" of drop in my '66 2WD on the front. I want the back up about 2" so there's a little slope. Do I really have to buy the drop I-beams? Will the alignment plague me if I don't?
I have a question for those of you with experience lowering these trucks. If you only want a few inches - not a "slam" - then can't you just buy the lowering springs and use a lower profile tire in front than in back? Do I have to buy the drop I-beams. I want about 2-3" inches lower in the front and 2-3" higher in the back - give it a little slope! Will I be plagued by alignment problems?
Now we're talkin'. All in fun. Sorry, but I have a soft-spot for farm trucks. Lowering should be reserved for rescued trucks. Like those ones from Seattle. Farm trucks are a special breed. The very essence of the pick-up. Not to be trifled with. But it's a free country. Thank God.
Hey FBP....I have measured about every possible thing I can think of on these frames..but never thought about adding the x members from a newer model...just thought about doing a whole clip or complete frame swap. I'm putting my '64 on a '79 chassis and all is going well...but, could I have put the front x members from my junk '65 into my '64????
Thanks for any input....and I'm gonna measure tomorrow!
yes. Alignment will be a nightmare if you cut or heat anything under your front end. If it had A -arms with coil springs. You could cut a coil off an still get it aligned pretty close. You cannot cut a coil off a spring with an I-beam front end. Find a set of Dream Beams. They will drop the front end right at 3-plus inches. If you cut 1/2 coil out. You should be able to still get it aligned.
. FIRST OF ALL......If you are going to do anything to a Twin i-beam truck. Go find yourself an old school alignment shop. Talk to them. Make sure they can heat & bend the I-beams to get the camber & caster set correctly. Most modern shops can't do these front ends properly. Make sure they can bend them properly.
. I've come across a few that have said they can. But when it came right down to it. They couldn't do the complete job.
. That's when I switched to Jaguar. The crown Vic front end is just to wide for my taste.
JAG is easy to install and very easy to align
good luck....
This is the part that is really nice about the Jaguar XJS IFS. It will bolt to the stock F100 frame rails. Just weld a bracket to the Jag. Cradle with 8 bolts on both sides. Lift the cradle up against your stock fram & Walla new independent front suspension.
no grafting frames. No zing the frame. Just a nice lowered truck.
good luck....
all good conversation, but do you realize your answering a question that was asked in 2005? Just sayin...
Reason: Typo
Yes, we noticed. This conversation and the ones like it all over the site should be consolidated into a couple of stickies. One being "suspension mods", and the other being "lowering your slick"
The Aerostar is even simpler and doesn't require any welding. Put the Aerostar crossmember under your frame, square it, drill the 6 bolt holes through the frame, bolt it in.
The challenges are; lining up the rack with a steering shaft, adding a power brake booster, and mounting any other engine besides the 4cyl, or v-6 which came in Aerostars. I built custom motor mounts for the 351 I put in mine.
I decided to go with a Helix "Corner Killer" Mustang II style front suspension , still doing all the work to the truck but it will be lowered 6 " total all the way around on QA1 coilovers , 20" wheels and 35 series tires , 1989 Mustang modded 5.0HO roller engine , 4 link rear suspension , 3.50 rear gears , 1" sway bars front and rear . and many other modifications ............ mainly just to give the purists a heart attack LOL
