Steering column rattle/ vibration
Old Oct 8, 2002 | 11:27 AM
mudmnky's Avatar
mudmnky
My column has been rattling since I got the truck. There is about a 1/16" play up and down from what appears to be center. I had the same prob in my 66 mustang and all it took was some new bushings. Is this going to be the same. If so how about some part #'s
Ryan
Old Oct 8, 2002 | 03:52 PM
dfisher1's Avatar
dfisher1
Ryan,
Do you have an automatic tranny or standard?
There are bearings in the column that must be replaced. I usually scavenge from the junkyard but, you'll find that the steering column is a weak link on this model truck and most are picked clean quickly.
Sometimes the shifter collar can wear out and it will rattle but this usually means its difficult to shift.
You'll need a repair manual,some patience, and some elbow grease.
KingFisher
Old Oct 9, 2002 | 09:58 AM
mudmnky's Avatar
mudmnky
Its a 302, 4spd. I wasn't planning on getting used parts to fix it. I've run into situation where all I did was take a column apart and put bad pieces right back in.
Ryan
Old Oct 14, 2002 | 03:59 PM
dfisher1's Avatar
dfisher1
Ryan,
Your going to have a bad time getting replacement parts. I went to the dealer with parts in hand and the guy looked at me like i was crazy. He was right! They say he'll walk again, someday?
Anyways, maybe the web store here could help you.
My Way is the Highway,
KingFisher
Old Oct 14, 2002 | 04:22 PM
Mistro's Avatar
Mistro
Ryan Sigman
Apr 13, 2013 11:49 PM
Punisher29073
Jan 20, 2013 11:19 AM
Ryan50hrl
2004 - 2008 F150
Apr 13, 2010 11:02 AM
59'er F100
Apr 10, 2007 03:23 AM
ryans428
Jun 7, 2005 03:02 PM
