What is this thingamabobber??
Old Oct 13, 2002 | 01:52 AM
Mistro's Avatar
Mistro
Ok, On my 74 F100 4x4 behind the transfer-case there is a driveshaft that goes to a crossmember with a big U-shaped strap that houses a rubber disc with the other end of the driveshaft that rides on a bearing in this disc. the other end of the driveshaft connects to this then goes to the pumpkin. Now when I push or pull on the front-rear driveshaft if moves quite a bit and the rubber seems to be in pretty bad shape. I am guessing that this is bad and now, what do you call it. Very confusing description I know. thanx
Old Oct 13, 2002 | 02:53 AM
todd_adams2001's Avatar
todd_adams2001
[updated:LAST EDITED ON 13-Oct-02 AT 03:55 AM (EST)]sounds like a watch-uh-ma-call-it. ??? kinda coupling ???
Old Oct 13, 2002 | 03:37 AM
heathdaily's Avatar
heathdaily
I believe you're describing the carrier bearing. The rubber around them is usually in poor shape. If it's real bad you'll need to replace it.
Old Oct 13, 2002 | 02:02 PM
Franklin2's Avatar
Franklin2
http://www.partsamerica.com/product_images/AAP/BCA/BEARINGS/00094A.jpg
Is this it? It's about $22.00 at the parts store.
Old Oct 13, 2002 | 10:09 PM
jagabom's Avatar
jagabom
Also called a hanger bearing, I believe.
Jim
CYWG
Old Oct 13, 2002 | 10:41 PM
albertafarmer's Avatar
albertafarmer
It's the drive shaft steady bearing, very easy to change and fairly cheap
Old Oct 14, 2002 | 01:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
Driveshaft Carrier Bearing, cheap at any good parts store, and easy to put in.
Old Oct 14, 2002 | 04:22 PM
Mistro's Avatar
Mistro
Thanx guys.
Old Oct 14, 2002 | 04:37 PM
Graffe's Avatar
Graffe
spikinfool05
16
Dec 4, 2012 09:26 PM
bad12jr
23
Jun 18, 2012 08:15 PM
robert_l_ross
Jun 19, 2011 10:06 PM
camcole
Jun 8, 2003 08:43 AM
