Getting Excursion on jack stands
Old Aug 7, 2005 | 06:05 PM
hink10's Avatar
hink10
This may be a stupid question, but I was wondering what was the best way to get an Excursion on jack stands. I need to rotate the tires and a few other things. Doesn't look like there is room on the axle for a jack and a jack stand due to the shock mounts. Everything I've read says not to jack from the differential. I haven't really studied the front yet. Any help would be appreciated. Thanks.
Old Aug 7, 2005 | 07:08 PM
jschira's Avatar
jschira
Just rotated my tires.
On the front, you can jack where the blocker beam bolts to the frame if you have a long enough jack.
Or you can do what I do (and have been for 30+ years) and jack on the diff.
Old Aug 7, 2005 | 08:00 PM
hink10's Avatar
hink10
Thanks for your help. I used to jack my expedition from the differential with no apparent problem. Just wanted to make sure.
Old Aug 7, 2005 | 11:41 PM
jschira's Avatar
jschira
I have also heard that you should not do it, but I have never heard why.
I have also never heard of anyone getting into trouble by using the diff.
Old Aug 7, 2005 | 11:55 PM
Munkey's Avatar
Munkey
I just use my Hi-Lift on the front tow hooks to get jackstands under my truck. . .I do get strange looks from the neighbors each time though...
axelgawn
Jun 21, 2017 06:33 PM
HRTKD
All Things Towing
Apr 13, 2017 10:14 AM
FireEngineMike
1947 and Older Ford Trucks
Nov 9, 2016 08:52 PM
jasonodsky
Sep 21, 2016 09:33 PM
tombob
1978 - 1996 Big Bronco
Aug 28, 2005 12:08 AM
