1978 - 1996 Big Bronco
pop while four wheeling
Old Aug 11, 2005 | 09:31 PM
Hamfisted's Avatar
Hamfisted
I bet you broke one of the Auto hubs....
I bet you broke one of your Auto hubs. I broke one and it was still driveable but the front wheels wouldn't pull. I replaced the front Auto hubs with a set of Warn Premium hubs. I had to get that special huge socket tool for the lock nut though. I think you need the hub nut kit from Warn too for your '96.
I got my hubs and the conversion kit from AccessConnect.com for about $120.
Part number 20990 for the hubs and 32720 for the conversion kit with the replacement nut and ring.
Warn Premium Hubs from Access Connect
Mike
'96 5.8L EB
Old Aug 12, 2005 | 06:34 PM
MTT460's Avatar
MTT460
no, the hubs are not auto locking. its manually done, however on a normal factory hub there may be a chrome metal piece, but it is accompanied with a series of screws which affixes the hub to the steel rotor with hub attached.
Old Aug 12, 2005 | 08:28 PM
brokebronco's Avatar
brokebronco
Originally Posted by MTT460
i have a question if someone has an answer. ok. i have an 88 fullsize bronco, and will be in the process of doing a frame up. i dont particularily like my front hubs. they look nice, but i dont under stand why ford had to put those on. i will describe them as a chrome looking entire hub. i was wondering if one could replace them with warn or something. ps. i have only seen these hubs on a few of this vintage.
You have the hat style hubs. To replace them with the better setup you need to change everything from the knuckle out. Check the boneyards, they usually let the ttb stuff go pretty cheap. While you are at it change all four ball joints and the axle u-joints.
Chris
Old Aug 13, 2005 | 12:46 PM
MTT460's Avatar
MTT460
thanks again, you are the first person who has had an answer to my question regarding the hubs.
Old Aug 14, 2005 | 12:22 PM
brokebronco
Yeah, I swapped a 82 front end into the 88 I sold to my buddy. He loves the better settup. He did some easy wheeling with your style hubs but was worried about breaking them and wanted to swap them out. I had the 82 I was parting out so I hooked him up.
He got it free due to being my designated driver all the time. Gotta apriciate that.
Chris
mzender
2004 - 2008 F150
Jan 24, 2013 04:37 PM
mechelement
21
Oct 31, 2010 11:47 AM
Jughead
Oct 18, 2010 03:16 PM
Aquaman78F100
1983 - 2012 Ranger & B-Series
Jan 21, 2008 02:52 PM
BigB4000
Offroad & 4x4
May 1, 2003 11:51 PM
