Sealing up the firewall...
Old Aug 7, 2005 | 11:30 AM
Unimog005's Avatar
Unimog005
I really really need to seal all of the holes in the firewall, as engine heat and fumes both baste and cook me while driving. Obviously, I will need to buy the little rubber seal for the clutch rod....but I really don't care to pull the entire wiring harness to install gromets in all of their holes....So, I am thinking of using the "firestop" silicone sealant that they carry at the home depot for use in firproof assemblies in homes....I though it might best resist the temperatures...has anyone found a better way?
Old Aug 7, 2005 | 11:43 AM
jor's Avatar
jor
You could install grommets with the harness in place by slicing them and fitting them around the harness.
jor
Old Aug 7, 2005 | 12:58 PM
thesprocket26's Avatar
thesprocket26
Do both. Silicone the grommets in the firewall. That is your best bet.
Old Aug 8, 2005 | 02:03 PM
rebocardo's Avatar
rebocardo
You can buy firewall shields of metal from someone (forget who?), couple that with insulation and chalk and you should be all set. I usually just use red RTV or GE's Silicone II to fill firewall or body voids. Just make sure whatever you use is resilent and flexible. The seals around the brake booster and steering columns sometimes need work too.
everyreggie
Sep 28, 2011 02:59 AM
Neil64
Mar 26, 2010 06:22 AM
86sixbanger
Nov 11, 2009 01:18 AM
svooom
Jun 18, 2005 12:01 PM
packrat56
Jul 30, 2004 10:12 AM
