Firewall Question
Old Sep 24, 2011 | 09:09 PM
everyreggie's Avatar
everyreggie
Firewall Question
Hi Guys,
I have a 1969 ford f-250 ranger, I am getting a tremendous amount of hot air coming through a hole in the firewall where the brake arm meets the firewall. Is there a gromet or way to seal this up that you are aware of??
Thanks
Old Sep 25, 2011 | 10:29 PM
everyreggie
Bump Please
Old Sep 26, 2011 | 02:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Is there a grommet or way to seal this up that you are aware of?
If you're getting that much hot air thru the firewall, I doubt it has anything to do with the master cylinder (or booster if power brakes).
There is a seal on the pushrod, but what air that could pass thru it, would barely blow out a match!
More than likely you need a new steering column seal. 1969: There are three different types.
I need to know two thing: With or without P/S? What is the last 6 digits of your trucks VIN?
Old Sep 27, 2011 | 02:59 AM
everyreggie
So the hole is about 2-3 inches across and is located right where the arm of the brake goes through the wall.
Last 4 are 9894
Thanks
Old Sep 27, 2011 | 03:26 AM
NumberDummy
What brake "arm" passes thru the firewall? I don't know of any. The master cylinders pushrod has a rubber seal on it, but any air that could blow past it, would barely put out a match.
There is a large rubber seal at the bottom of the steering column, butts up against the firewall. If a tremendous amount of hot air is blowing into the cab, I would suspect this seal has been compromised.
There are three different seals, and since your '69 has P/S, there are two types used in 1969, Bendix & Ford. Before/from serial number D96,001 is the deciding factor, so the last 4 digits of the VIN are worthless to me.
Old Sep 27, 2011 | 09:19 AM
tmcalavy's Avatar
tmcalavy
You're both right. When the rubber boot that is supposed to surround the brake pedal rod/plunger that goes into the master cylinder ruptures or wears out, the boot draws up against the back of the master cylinder and you get a lot of hot air in through that hole in the firewall. I figured the part was obsolete when this happened on mine, so I didn't bother trying to source a replacement. I got a chunk of foam pipe insulation, cut it about 6 inches long and split it and used it to fill the gap around the rod/plunger...also put some lube on the side that surrounds the rod/plunger. It's long enough to stay put and lets the rod/plunger work like normal, plus no hot air in the cab unless I open the floor vents.
Old Sep 28, 2011 | 02:59 AM
everyreggie
sorry last 6 of vin is E29894
PROSTOCK
Mar 8, 2022 10:31 AM
JustBlaze
Jul 25, 2013 10:16 AM
Mikestrucks
Feb 9, 2007 11:32 PM
stephenw
Feb 4, 2004 03:48 PM
Whiskers
Apr 13, 2001 10:25 PM
