Fuel problems Help please
Old Aug 6, 2005 | 12:25 AM
freebird914's Avatar
freebird914
Question Fuel problems Help please
96 explorer v-6 I have no voltage getting to the fuel pump and I have checked the relay and fuse the indications I have are a open in the wiring ... Using a voltmeter ..... I can ohm the wiring bewteen the fuel pump and wiring harnest under the seat and have a connection.. Anyone have a schmatic and know where the wiring goes after it comes up under the seat? Can I run a temporary wire to power the fuel pump or any other ideas... Thanks
Old Aug 6, 2005 | 07:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 6, 2005 | 10:55 AM
87 XLT's Avatar
87 XLT
Next up is the inertia switch. I dont have a wiring diagram for a 96, but my guess would be that it's under the dash/passenger side where the rug meets the firewall. If it's not there, your owners manual will tell you where it is.
Check for voltage at the inertia switch.
Old Aug 6, 2005 | 04:32 PM
freebird914
Whats after the switch.... Thanks anything in front of the switch?
Old Aug 6, 2005 | 05:04 PM
Craig789's Avatar
Craig789
On my 94, the fuel pump relay was fed electricity by the adjacent electronic controller relay. I think they were interchangable. Try plugging in a "known good" relay in both locations.
Old Aug 6, 2005 | 05:14 PM
87 XLT's Avatar
87 XLT
Fuel pump relay to inertia switch to fuel pump.
BTW you will only see voltage for 2 seconds after you turn the key to run.
You really should have a wiring diagram. Might find one online at autozone.com
And like craig said, you can try swapping relays
Old Aug 6, 2005 | 09:04 PM
dogman's Avatar
dogman
Sound like the anrusha-switch (for give the spelling not my best side) may be tripped. Mine is drive side in back over rear wheel.
Old Aug 7, 2005 | 07:20 AM
marragtop's Avatar
marragtop
Also, make sure that the plug on the bottom of the inertia switch is tightly connected.
MYBOYDAVE
Sep 9, 2013 04:15 PM
BURNSTOUGHFORD
40
Mar 27, 2013 05:22 PM
brettcp
Dec 4, 2012 07:33 PM
skookum
Aug 2, 2010 09:34 PM
Bayer-Z28
General Automotive Discussion
Mar 21, 2010 01:08 PM
