96 explorer v-6 I have no voltage getting to the fuel pump and I have checked the relay and fuse the indications I have are a open in the wiring ... Using a voltmeter ..... I can ohm the wiring bewteen the fuel pump and wiring harnest under the seat and have a connection.. Anyone have a schmatic and know where the wiring goes after it comes up under the seat? Can I run a temporary wire to power the fuel pump or any other ideas... Thanks
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Next up is the inertia switch. I dont have a wiring diagram for a 96, but my guess would be that it's under the dash/passenger side where the rug meets the firewall. If it's not there, your owners manual will tell you where it is.
On my 94, the fuel pump relay was fed electricity by the adjacent electronic controller relay. I think they were interchangable. Try plugging in a "known good" relay in both locations.
