1978 - 1996 Big Bronco
Rear brakes dragging?
Old Aug 5, 2005 | 01:29 PM
lukedraper's Avatar
lukedraper
Little history, I replaced my rear brake drums and pads because my anti-lock brake and e-brake light were on. Figured pads were gone, they were. After replacing my shoes the rear brakes drag intermitently. So I replace the Master cylinder and the ABS sensor. Probelm goes away for about 24 hours and now my breaks are dragging again randomly. There is no pattern to them dragging but they obviously are. I took the truck to good guys and they verified that my shoes were installed right and adjusted properly. The truck has no codes and they don't know what it is. I question if there mechanic knows what he is doing so I have another buddy check my shoes and he too says they look good. Any ideas?
Rear brake cylinders? Is there anything left that would cause this? I am not an idiot but I am at a loss and tierd of replacing parts that make no difference LOL
Luke
89, 302, AOD, stock
Old Aug 5, 2005 | 01:36 PM
lukedraper's Avatar
lukedraper
Well, I seem to have forgotten that there is a search feature on here.
This link describes exactly what happened.
https://www.ford-trucks.com/forums/s...ht=rear+brakes
Looks like my ABS could be bad or have air in it.
Luke
Old Aug 5, 2005 | 03:49 PM
Kemicalburns's Avatar
Kemicalburns
did you grease the back plate were the brake shoes rub? if not this could cause it to grab and hold intermitently. also bleeding your brakes in the proper order makes a difference as well.
Old Aug 5, 2005 | 11:33 PM
chrono4's Avatar
chrono4
it could also be that you have blockage in one of the lines, when under high pressure on application, it would let fluid through, but on low pressure return, it would hold it back. check the rubber lines esp.
Old Aug 5, 2005 | 11:38 PM
kameronth's Avatar
kameronth
It sounds like your abs valve to me. Mine took a dump on me and i had the same exact symptoms. The valve is right by the fuel filter on the frame.
Old Aug 6, 2005 | 07:39 PM
lukedraper's Avatar
lukedraper
Cost? Part number to call around?
Common pooint of failure?
Old Aug 23, 2005 | 11:06 PM
Tazz452's Avatar
Tazz452
I was told that the dealership was my only source for the part. At $200 I am looking for alternatives.
Old Aug 24, 2005 | 12:19 AM
andym's Avatar
andym
It's quite common. I've seen it on a number of Ford trucks.
Old Aug 26, 2005 | 02:47 AM
OCExpy's Avatar
OCExpy
Check out AutoZone. Came up as "ABS Unit" for my '88
tuxedobuttonquail
Sep 23, 2016 03:40 PM
Gembone
15
Oct 31, 2015 07:18 PM
95f3507.3
Oct 21, 2015 06:36 AM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
Jun 6, 2015 10:50 AM
G2IC_Wraith
Jun 6, 2015 10:49 AM
