Sponsored by: Kumho
Steering filter?
Old Aug 3, 2005 | 04:23 PM
wickymustang's Avatar
wickymustang
Steering filter?
I have a 1995 F150 2wd with the 300 six cylinder. I was going to change the power steering fluid since it is the original and very badly burnt and discolored. I know the fluid I need to use, but I was told by several people that I should put a filter in the return line just before the pump. The problem is I can't find a filter anywhere. I tried Checkers, and all the other parts houses around here and nobody has any. So where should I look now?
Old Aug 3, 2005 | 07:51 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
I run a cooler from later (99 up) Ford trucks plus use Neo oil, the same oil used on race car PS units.
.....=o&o>.....
Old Aug 3, 2005 | 09:37 PM
Ecuri's Avatar
Ecuri
https://www.ford-trucks.com/forums/s...d.php?t=102632
Post #10
Autozone has a slip-in that resembles the orifice tube/filter in an A/C system; I'm sure the above described system is much better, but anything is better than nothing.
Old Aug 6, 2005 | 10:04 PM
wickymustang
That is from the 1973-1979 era trucks section, would this still work on my 4.9L 95 F150?
Old Aug 6, 2005 | 11:05 PM
ivanribic's Avatar
ivanribic
Yes, same exact setup, just goes into the return hose on the power steering.
Old Aug 7, 2005 | 06:46 PM
wickymustang
Alright, so which parts house carries wix or should I just go to the local stealership to get this?
Old Aug 7, 2005 | 06:55 PM
"Beemer Nut"
How many micron is this filter for the power steering and does it restrict oil flow back to the pump? I have a completly new system and only run a magnet.
.....=o&o>.....
Old Aug 7, 2005 | 11:11 PM
Ecuri's Avatar
Ecuri
I believe NAPA carries WIX brand.
I have no idea what the micron rating is, but all the wore-out systems I have fixed had stuff visible to the naked eye. I did a F-600, mid-70's box for a buddy recently that had an integral filter in the pump. There was a lot of junk inside this old trucks resevoir! (The pump was still fine, the box was slop.)
I stuck one of the auto-zone cheapie's in my return line after changing a pump (again, lots of grey-matter), my thought is replace it in a month. If it clogs and restriction becomes an issue, I don't think it will hurt anything... just time to install a new one.
Old Aug 8, 2005 | 10:57 AM
"Beemer Nut"
ecuri,
did you do a magnet check on that gray matter, could be iron paste like what's around the engine oil drain magnet, normal wear?
.....=o&o>.....
Old Aug 8, 2005 | 11:24 AM
Ecuri's Avatar
Ecuri
No, I didn't, I just flushed and cleaned the system as best I could. I expect the boxes and racks make ferrous, I have no idea what material the impellers are.
Old Aug 8, 2005 | 02:49 PM
RawPower's Avatar
RawPower
Hey Ivan, your running Hydro assist right? Are you using a filter? If so, what is it?
Old Aug 8, 2005 | 06:52 PM
"Beemer Nut"
Power steering pumps are 100% iron inside, any aluminum from the rack is harmless but iron particles will cause damage as well dirt in the system.
I sleep better knowing there's a magnet in the pump. I use NEO steering oil, it lubricates better than ATF.
.....=o&o>.....
Old Aug 8, 2005 | 08:05 PM
wickymustang
Where can I get NEO oil?
Old Aug 8, 2005 | 10:24 PM
"Beemer Nut"
That would be NEO synthetic oil, high performance power steering fluid that is a lightweight hydraulic fluid. It was developed to eliminate gear scuffing and flaking in racing power steering units. NEO oil company, signal hill Ca. 90806.
I think it was around $5 a quart before shipping. They ship fast like two days from southern Cali to northern Cali. Hope this helps, Carl.....=o&o>.....
Twonky
Mar 3, 2017 11:59 AM
Jack Frost
Sep 29, 2013 07:28 PM
wicat3
15
Sep 24, 2012 06:20 PM
Smith76
Mar 8, 2006 09:11 AM
SDJERSEY
Aug 7, 2004 07:52 AM
