has anyone replaced these with a poly aftermarket set up? Im interested in doing this, but nobody can tell me what sizes i need. They list like 15 sizes for 97 - 01 Expis. I have an 01 XLT 4x4...if anyone can point me where to order a decent set up that will be the right size for my front and rear sway bars, that would be great! Ive looked at energy suspension and Mako, but again, so many sizes to choose from...
Thanks!
I tried the copy/paste, not so good - go directly to the site From energysuspension.com:
Expedition & Navigator 4WD
Year Front End Control Arm Bushing Set Rear End Control Arm Bushing Set Rear Track Arm Bushing Set Body (Cab) Mount Set Complete
Front Sway Bar Bushing Set Complete
Rear Sway Bar Bushing Set Tie Rod
Boots
1997-01 .4.3145
(2) 4.3146 4.7121 4.4111 33mm
4.5145 22mm
4.5146 (103)(123) 9.13101
(72)
1997-01 Expedition/Navigator 4WD HYPER-FLEX SYSTEM Complete Master Set Includes: front and rear control arm bushings, front and rear sway bar bushings, body mounts, rear track arm bushing and tie rod end boots. 4.18115
Now I'll probably get yelled at for not supporting this forums sponsers.
From the same site but not copy/paste:
Complete Front Sway Bar Bushing Set - 33mm, 4.5145
Complete Rear Sway Bar Bushing Set - 22mm, 4.5146 (103)(123) Not sure what the parenthesis means.
