brakes question
Old Aug 1, 2005 | 03:14 PM
hayfork67bronco's Avatar
hayfork67bronco
brakes question
back to work on a 1972 ford f100 4x4. the brakes are shot, wheel fell off and ground the brake backing plate down a bit. i wasn't there and havn't seen the truck since. my question is, did that year come in two differnet size brakes? i would guess 11 and 9? also, what size would the brake lines be? its the driver rear side. needs backing plate, brakes and brake lines.
any advice is welcome.
Old Aug 1, 2005 | 03:18 PM
1975Ford's Avatar
1975Ford
Check the junkyard for the parts you need.
Old Aug 1, 2005 | 04:55 PM
thesprocket26's Avatar
thesprocket26
As far as I know, 67 was different from 68 and I don't know about the other years. 67 has smaller drums and shoes. 68+? has the larger drums and wider shoes. I don't know what "11" and "9" are. The hard brake lines are 3/16", US thread, standard flare. You can buy these at the auto parts stores.
Old Aug 1, 2005 | 05:06 PM
hayfork67bronco
the 9 and 11 were in reference to the drum size, in inches. maybe i am off, just a guess. its on a 72 f100 not the bronco...
alex
Old Aug 1, 2005 | 05:08 PM
thesprocket26
The only thing I can think that has 9" drums are cars. My drums are like 11+ inches.
Old Aug 1, 2005 | 05:18 PM
hayfork67bronco
thanks,
reason i am asking is i need to get the backing plate. thanks for the help.
Old Aug 2, 2005 | 09:55 AM
rebocardo's Avatar
rebocardo
You should have 11 x 2 1/4 or 12 x 2 1/4 drums. Been a while, but, I think mine were 12 x 2 1/4. Then again, probably not the factory 9 inch either. They never put a 9 inch drum on a F-100/F-150. I think my Ranger had bigger drums then that.
The brake line is 3/16. Make sure you get the non-metric/non-British line if shopping at Autozone or other stores.
12" drums in the front and back. The fronts are a 1/4" wider. If the wheel fell off it is probably because the drum is meant to be pressed unto the hub.
Old Aug 4, 2005 | 05:34 PM
hayfork67bronco
one more thing to bother you all with...
if anyone could give me the length of the hard brake lines for the rear it would help.
again, 72 f100 4x4
alex
Old Aug 4, 2005 | 05:38 PM
1975Ford's Avatar
1975Ford
Are you looking for the brake line length on the rear axle housing?
Old Aug 4, 2005 | 05:48 PM
thesprocket26
If you can double flare then you can make your own. Otherwise you can order them through parts magazines for the correct length. If you buy them at the parts store they will be close. You will need a measuring tape to figure out how long of a piece you need to buy. Then piece it together. I think on the rear I used a 20" piece and a 32"/40" piece. Then the rubber line up to the frame, and two 60" pieces up to the porportioning valve.
Old Aug 4, 2005 | 05:52 PM
hayfork67bronco
i am looking for the length on the rear axle housing, looks like its 20" and 32" or 40"?
Alistair 1924
Dec 5, 2016 12:32 PM
59203shop
Apr 17, 2016 11:22 PM
TwistedFate
Apr 15, 2015 12:00 AM
96f150
1997 - 2003 F150
Sep 29, 2014 07:04 PM
Itsme7
May 24, 2009 04:51 AM
