Bolt size question
Old May 23, 2009 | 11:32 AM
Itsme7's Avatar
Itsme7
Bolt size question
I removed the diff. axles, and brakes from my 65' f100 with 9" 10 bolt ford rear end. The 4 studs that hold the backing plate and bearing retainer plates on, does anyone know the size and pitch thread they are? The nuts were pretty mauled, dont want to put them back on. Thanks for your time.
Old May 23, 2009 | 04:27 PM
drof46's Avatar
drof46
I'm not sure, but if you get in a pinch you could always run down to Fastenal.
Old May 23, 2009 | 07:44 PM
Itsme7's Avatar
Itsme7
Thanks. I think its a 7/16-20, might just order up some nuts to see if its right.
Old May 23, 2009 | 10:28 PM
LM14's Avatar
LM14
If you used a 3/4" socket to remove them (as all 9" big bearing rearends use, probably what yours is, usually trucks and performance and large cars) then you need 1/2" fine thread lock nuts. If you used an 11/16" socket (most common car rearends with small bearings) then you need 7/16" fine thread. Remember, these are lock nuts with the deformed/crimped ends, not nylock nuts.
SPark
Old May 24, 2009 | 04:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Itsme7
I removed the diff. axles, and brakes from my 65' f100 with 9" 10 bolt ford rear end. The 4 studs (As original: BOLTS) that hold the backing plate and bearing retainer plates on, does anyone know the size and pitch thread they are? The nuts were pretty mauled, dont want to put them back on. Thanks for your time.
C2AZ2248A .. Bolt-Bearing Retainer / 1/2" -20 x 1 29/64"
PARTS INTERNATIONAL in Farmers Branch TX has 44 = 888-727-0418.
GREEN SALES COMPANY in Cincinnati OH has 12 = 800-543-4959.
55753S2 .. Locknut-Bearing Retainer Bolt / 1/2" -20 ~ National Fine Thread / Obsolete
SMITH MOTOR COMPANY in Washington NJ has 2.
GREEN SALES has 141.
bbf385
May 8, 2016 10:27 PM
garagespa
Apr 29, 2016 01:21 PM
Diverjeff
May 29, 2015 07:14 PM
MAULMAUL
Nov 22, 2010 04:54 PM
