Sponsored by: Auxito
door lock actuator installation
Old Jul 31, 2005 | 08:24 PM
ozbo's Avatar
ozbo
Talking door lock actuator installation
Folks: I feel like I did the impossible. After hearing all kind of horror stories on actuator installation on 2000 Lariat, I decide to tackle it any way. It was mainly the $200 dealer labor tab that gave me the impetus. Its easy after you get the old one out. Did right side; left side will be a breeze. Once you get the door panel off and electrical plugs pulled, it helps to disconnect screw holding window slide to the inside panel and move the slide out of the way toward the hinge side. Take out three screws holding door lock and move whole assembly to position to remove push rods and actuator elec. plug. Use small screw driver to slip actuator snap loose and remove it. New one goes back in easily. Put all your plugs back and walla! Felt good! oz
Old Aug 1, 2005 | 10:33 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Thanks for the tip. Replacing the actuators seems like a pretty common job on here.
Old Aug 1, 2005 | 01:49 PM
lancekilgore's Avatar
lancekilgore
excellent, good job thanks for the info, will keep for future uses.
Lance
CUINAK
Sep 27, 2019 10:48 AM
FUJINAMI1293
Jun 17, 2012 08:03 AM
damons
Jun 8, 2012 12:54 PM
navstar
Jan 26, 2004 11:22 AM
Braveheart
Sep 9, 2003 11:33 AM
