Help, Help
I dont know what the normal sound that my 7.3 should be making, I look around at the threads and still become clueless on if my truck is knocking or just a normal deisel rumble. History on my truck 95 auto, Im getting 19 mpgs consistanlty, if I had a bad knock/rod going what would be the signs other than noise. I get a little smoke on start up, nothing while I drive, I idle at 600 - 700rpms, I have great power at a stop and while at speed, I can pass a crotch rocket like it was standing still. Some say CPS, injector, or go to a HX mod??. One where is the CPS, two, in my neck of the woods a CPS is 300 beans$$. Injector? how hard is it to change out one, what to buy do just # 8injtr, I like to do the work myself and have done alot on my old truck, so I need some advice. If it was a bad rod what would I be looking for or feeling from my truck??
MB
As for the CPS, check this out. It's a pretty handy quide to have sometimes.
I have had mine for over a month and been everywhere with it and no one has said, Hey that truck sounds bad. I have been to a mech for front end work and to my parts dealer to many time to count for other parts. Like I said, and like you have said it runs loud but it still has all the ***** a 7.3 can deliver. thanks for the guide(chart).
Full price on the CPS I think is about $185.00. (check our sponsors for prices). It takes a 10mm wrench. Never did it but they say it is easy. No idea on the injectors. Maybe do a search to get more info. I would not start changing things without knowing for sure what if anything is wrong. Good luck with it.
Joe
p.s. fill in your signature describing your truck, it will help others help you.
MB
^ ENGINE - 7.3L DIESEL - ENGINE KNOCK OR
"CACKLE" - 1999-2000 SUPER DUTY F-SERIES AND
2000 EXCURSIONS WITH ENGINE SERIAL
NUMBERS 661894 THROUGH 1311240 - ALL
1998-2000 E-SERIES WITH ENGINE SERIAL
NUMBERS 661974 THROUGH 1311240
^ NOISE - "CACKLE" OR ENGINE KNOCK - 7.3L
DIESEL - 1999-2000 SUPER DUTY F-SERIES AND
FORD:
1998-2000 E SERIES
1999-2000 SUPER DUTY F SERIES
2000 EXCURSION
This article is being published to combine TSB 00-22-1 and 01-14-6 as part of a consolidated 7.3L diagnostic aid booklet.
ISSUE
Some vehicles equipped with a 7.3L Powerstroke diesel engine with engine serial number 661894 through 1311240, may exhibit a noise above the normal sound of the diesel combustion. This noise may sound like a rod knock, but it is intermittent and increases in intensity as the engine warms up to operating temperature. This "cackle" noise may by caused by pressure variation within the fuel rail and in virtually all instances is attributed to cylinder # 8 (driver side rear). The "cackle" noise does not cause damage the engine, or impact the engine's performance or economy.
Engines after serial number 1311240 were built with a long lead injector in cylinder # 8 and correct calibration from the factory. It is possible for engines with the long lead injector, from the factory or installed in service, to exhibit a "lifter noise" (the long lead injector can be identified by the "LL" stamp on top of the solenoid.) This noise is typically most noticeable when the vehicle is parked next to a brick or concrete wall, such as at a fast food drive through. This noise is a normal characteristic of the long lead injector and is not a reason to replace the injector.
ACTION
Refer to the following Service Procedure for diagnostics, injector replacement, and Powertrain Control Module (PCM) reprogramming procedure.
SERVICE PROCEDURE
The "cackle" noise will typically be found early in an engine's life due to low fuel pressure and/or the relationship of injectors and engine firing order, or fuel pressure below specification. If a mature engine develops the "cackle" noise, low fuel pressure is the likely cause. Before making a repair attempt, the following tests should be performed:
1. Verify that the noise occurs with a hot engine, not cold.
2. Verify that the vehicle has been driven long enough to purge the air out of the high-pressure oil system and the fuel system since the last injector/high pressure oil system repair. Air trapped in the system could induce the "cackle" noise.
3. If the fuel pressure is less than 379 kPa (55 psi) in either head, repair it first and re-evaluate the "cackle" concern.
4. Repair any other engine driveability concerns prior to attempting a repair for "cackle". Example: low fuel pressure concerns may be causing low power and "cackle". Repairing the low fuel pressure may correct both concerns. Also, an engine miss may be an indicator of valve train concerns.
5. Verify that there is no air entering the fuel system. Air entering the fuel system will affect injector timing, causing unusual noise/performance.
6. The Injector Performance Analyzer can be used to determine if the "cackle" is coming from cylinder # 8. Cancel that cylinder to determine whether the noise still exists. "Cackle" cannot be identified using the Cylinder Contribution Test.
If the noise is only present when engine is hot, and:
a. no performance concern exists
b. fuel pressure is above the minimum specification of 379 kPa (55 psi)
c. there is no air present in the fuel/oil system
d. a long lead injector is currently not installed
then the engine is a candidate for a special Injector, F81Z-9E527-EARM (engine s/n 661894 - 896811) or XC3Z-9E527-AARM (engine s/n 896812 - end of 7.3L production).
NOTE IF THE NUMBER EIGHT INJECTOR HAS BEEN REPLACED PREVIOUSLY FOR A CACKLE NOISE CONCERN WITH PART NUMBER NOTED ABOVE, DO NOT REPLACE IT AGAIN. THE LONG LEAD INJECTOR CAN EXHIBIT A TICKING "LIFTER" NOISE AT NORMAL OPERATING TEMPERATURES. THIS IS CONSIDERED A NORMAL CONDITION AND DOES NOT REQUIRE SERVICE.
NOTE THE ENGINE SERIAL NUMBER CAN BE FOUND ON THE LOWER LEFT SIDE OF THE ENGINE BLOCK REARWARD OF THE OIL FILTER.
NOTE THE NEW LONG-LEAD INJECTOR FOR "CACKLE" NOISE IS USED ONLY IN CYLINDER # 8. DO NOT USE IN ANY OTHER CYLINDER DUE TO FUTURE CYLINDER CONTRIBUTION TEST DIAGNOSTICS BEING AT RISK. THE INJECTOR IS RECOGNIZABLE BY AN "LL" STAMPED ON THE SOLENOID WHERE THE UVC (INJECTOR HARNESS) CONNECTS.
Replace the # 8 injector by referring to the replacement procedure in the appropriate vehicle Workshop Manual. In addition to replacing the injector, the PCM MUST be reprogrammed to prevent the # 8 injector from flagging a false Cylinder Contribution Test code during future diagnostic tests. After the repair, realize that some small amount of "cackle" may remain.
NOTE VEHICLES BUILT WITH ENGINE AFTER S/N 1311240 HAVE CORRECT CALIBRATIONS FROM THE FACTORY
__________________
95 F250 ext cab long box w 3:55 Rear end, no mods, just a KN fltr, New fluids all around went w 5W 40 synt, I swear by my Red line additives. Does "cackle" apply to the 95 years. New CPS what will it do if its going, I have tach, one thing I have read that the tach starts to act up when the CPS is going.
p.s. you need to lose your cat and get a new d.p. and it will make your truck run 10x better.
hey check this site out lots of good info in there about easy mods to do all the acronyms we use here and how your truck works.
Whats a fpr ,screen, or shim it give me more of a low down
thanks
Mark
there is a screen when you remove(two 10mm bolts i think) fpr from side of fuel filter housing that gets clogged with crap from orings and other debris.
as far as shimming the fpr. get an old tire gauge you dont care about and with your truck idling take a reading at the schraeder vavle.( that is on the drivers side of the housing looks like a valve for filling a tire.) if its under 65 or so you wanna shim it. that is done by removing the brass nut19mm right above that and placing a 3/16 bb in there. if you need pics of this let me know. btw ideal fuel pressure is 70-80 anymore than that and it overworks your fuel pump. i say 65 is the cutoff point because if its higher or close to that you will have to high of pressure after shimming. all this stuff is under the big black cover on top of motor. if more help is needed or pics just let me know. if you do shim take a reading after to make sure you are close to 70 +/- a few and not to high.
dont forget to look at that site in previous post and bookmark it. you will need it again trust me.
I have the site booked marked now, good info for all the lingo, if you could send the pics my way would be great. I have done a fpr on my old 93 f150, any other suggestions on hx mod, and the injector #8, I thought the hx was for newer models?
