86 351 W HO Problem
Old Jul 29, 2005 | 08:01 PM
Junk4x4's Avatar
Junk4x4
Question 86 351 W HO Problem
My 86 Ford 4x4 truck had been making a tiny missing noise and several days later i was driving down the road when it lost all power and started sputtering really bad.Well when i found the distributor cap it was fried in the center so i replaced the plug wires cause they were old and replaced the cap .When i went to start it again it sounded like a steam engine and now is misfiring bad. Did it jump time or what? Any answers will be greatly appreciated!
Old Jul 29, 2005 | 08:15 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 30, 2005 | 12:25 AM
yozsi's Avatar
yozsi
sounds like you misplaced some wires.
Old Jul 30, 2005 | 06:01 PM
jpjahn's Avatar
jpjahn
Take off one wire at a time from the distributer (hold it as far back on the cap as you can or else you'll get electricuted) and see if you can tell which cylinders make a difference as far as how it runs. It will either make it run worse or no change when you pull each one off. You can find which ones are mixed up if thats what the problem is, and then switch them around too see if they make it run better. You could also wear a glove of some type if you want. I wouldn't recommend doing it my way if you have heart problems or anything like that.
Old Jul 31, 2005 | 05:57 PM
fordborn's Avatar
fordborn
Welcome to the sit "Junk4X4". I have moved this thread to the "221, 260, 289, 302, 351w V8" Forum. The people here should be along wiht some great help or ideas to your question.
mechelement
Jan 14, 2013 08:26 AM
SmittyGa
May 17, 2008 10:22 AM
wilsonriverfisher
28
Jul 26, 2006 10:28 PM
onetime_57
17
Jan 23, 2005 05:57 PM
QRFleader
1983 - 2012 Ranger & B-Series
Jan 19, 2004 08:01 PM
