Fuel injection flooding
Old Jan 16, 2005 | 09:47 PM
onetime_57's Avatar
onetime_57
I have an 86 Bronco 302 with fuel injection. The engine started running rough and missing badly.After replacing cap,rotor,plugs, and wires it still ran badly. I noticed that there was an insane amount of fuel consumption to the rate of half tank in 40 miles or roughly 3-4 miles a gallon and that large amounts of raw fuel is being kicked out the exhaust. I didn't think it was possible for fuel injection to flood.Any help is greatly appreciated.
Old Jan 17, 2005 | 01:39 PM
wickymustang's Avatar
wickymustang
Any codes? That would be the first place to check.
Old Jan 17, 2005 | 10:22 PM
onetime_57's Avatar
onetime_57
Can you check codes on an 86? And if so where?
Old Jan 17, 2005 | 11:50 PM
bigblocksix's Avatar
bigblocksix
for milage that bad something is horribly wrong like an injecter stuck open dumping fuel into the engine. if all else fails get your injecters tested and cleaned, its usualy good for a big more power to
Old Jan 18, 2005 | 08:30 AM
grease monkey's Avatar
grease monkey
Sounds like your injectors are stuck. I had that same problem on my probe. First I would buy a good bottle of injector cleaner like red line or any other good brand fill it up with premium and see if you can beak them open with the higher octane and cleaner.
Old Jan 18, 2005 | 09:04 AM
taylor0987's Avatar
taylor0987
Leaky injector.
They should be 19# injectors (orange). It might be cheaper to get new or low-mileage take out injectors that it would be to get yours cleaned/serviced/tested. Look at eBay, Mustang message boards, or at worst a set will be $210 from a high-performance catalog (i.e. summit racing-- get the Ford Racing Performance Parts ones).
Old Jan 18, 2005 | 10:53 AM
wickymustang
My bad, dislexia strikes again, thought it was 96
Old Jan 18, 2005 | 11:09 AM
docgreen's Avatar
docgreen
onetime try this first before you go sinking a lot of money in injectors. Replace the coolant temp sensor (for the ecm). When these fail they can and do give the ecm wrong info like that the coolant is at -32F (example) this causes the ecm to dump an insane amount of fuel into the chambers richning up the mixture. It'll run like poo until you replace the bad sensor. I had a g-marquis in my shop years ago just like what you described. Other shops had replaced everything and I mean EVERYTHING else on this poor ladies engine except the coolant sensor. They are cheap .... try it first. Just my $.02
Old Jan 18, 2005 | 12:30 PM
EPNCSU2006's Avatar
EPNCSU2006
Don't just throw parts at it hoping to fix the problem - with EFI that can get expensive in a hurry, and might not solve the problem. You can test the sensors with a volt meter to see if any are giving incorrect readings. You should still be able to pull the codes from the computer yourself, even on an '86. You will have to use an analog volt meter to read the codes since I'm guessing there is no check engien light in the dashboard. http://fordfuelinjection.com/index.php?p=13 has instructions for how to pull the codes. Instead of grounding STI to the chassis, you can just jump it to sig-rtn, and it'll do the same thing.
Old Jan 19, 2005 | 06:50 PM
LxMan1's Avatar
LxMan1
First, Check the vacuum line to the MAP sensor. If you lose vacuum to the MAP sensor, it will run way too rich.
Next, remove the vacuum line from the fuel pressure regulator.If the diaphram is bad, it will suck raw fuel into the engine thru the vacuum line. There should be no fuel in the line.
Good luck.
Old Jan 20, 2005 | 03:24 AM
onetime_57's Avatar
onetime_57
I replaced the coolant temperture sensor...No change.Vacuum to the map sensor I'll check next.Thanks for the input.
Old Jan 20, 2005 | 10:59 PM
LxMan1's Avatar
LxMan1
Keep us informed on what you find.
Old Jan 21, 2005 | 03:45 PM
onetime_57's Avatar
onetime_57
Alright I went and pulled the codes.This is what I got.
1>Throttle position sensor signal out of voltage specifications
2>EGR valve position sensor not in closed position or voltage incorrect
3>Unable to raise idle
4>Map sensor signal voltage out of specification or not at normal vacuum levels
5>Exhaust gas oxygen sensor reads always running rich
6>EGR valve is not opening or is not closed properly
7>Insufficient manifold vacuum change detected during dynamic respone test
Well those are the codes...Any ideas?
Old Jan 22, 2005 | 02:04 AM
Ford_Six's Avatar
Ford_Six
It sounds like the KOER test should be done again. Did you have it done at AutoZone?
Old Jan 22, 2005 | 05:20 AM
onetime_57's Avatar
onetime_57
Actually I bought a code reader from Autozone.I replaced the T.P.S. today and it seemed to have some improvement but it still is not running right.I plan on running the code check again tommorow.
