A/C thunk and i mean thunk
Old Jul 29, 2005 | 06:36 PM
WWBeast's Avatar
WWBeast
Aright everytime i turn my AC on when startin the truck i hear this clunk and its loud. Anyone else have this or know what it is...When i first got my truck the ac came out the defrost vents they fixed that but now im gettin this clunk noise....should i take this in or do yall know what it is..
Old Jul 29, 2005 | 08:25 PM
slc10844's Avatar
slc10844
It's normal. They all do it.
Old Jul 30, 2005 | 02:13 PM
guydiver12's Avatar
guydiver12
Mine does it. sounds like a loud WHUMP!!!!! when the doors down low under the dash somewhere slam shut. I actually thought I hit something in a parking lot once, got out to look around. Finally got used to it, but it still startles me once in a while, especially when I just went into gear and started moving.
Old Jul 30, 2005 | 05:33 PM
WWBeast's Avatar
WWBeast
ya i was like wooo this is nuts so thanks for the input
Old Jul 30, 2005 | 11:23 PM
Dieselhound's Avatar
Dieselhound
Lately, my AC makes a fluttering noise in the dash board diverter valve that sends the flow to the defrost or normal dash vents. After a bout of the diverter fluttering, the air flow, (ac or normal vent) will only come out the defrost holes, no matter where I set the controls. It has happened 3 times and usually flops back to normal after about 30 minutes or another re-start. It it keeps doing it, might need a trip to the shop. Besides that, engine is running strong. Last tank of fuel got a calculated 16.7 mpg, on a trip to Mexico with a fair load inside that huge Leer 122 camper shell. (picks in my gallery. Even a Kawasaki KLX 300 motorcycle or Suzuki King Quad can fit inside that camper shell).
Old Jul 31, 2005 | 12:02 AM
WWBeast's Avatar
WWBeast
Ya man thats exactly what happened to me when i first bought it just take it to the dealer takes like 30 mins for them to fix forgot what they said was wrong but ya its a quick fix
Old Jul 31, 2005 | 05:20 AM
slc10844's Avatar
slc10844
[QUOTE=Dieselhound]Lately, my AC makes a fluttering noise in the dash board diverter valve that sends the flow to the defrost or normal dash vents. After a bout of the diverter fluttering, the air flow, (ac or normal vent) will only come out the defrost holes, no matter where I set the controls. /QUOTE]
Sounds like a vacuum problem. Check inside for a hissing noise around the dash, which would indicate a bad valve or loose hose. Also check the vacuum lines under the hood for splits and being loose.
Old Jul 31, 2005 | 08:14 AM
Ford_Doctor's Avatar
Ford_Doctor
Another common thing that causes that is the vacuum pump. The diesel trucks have an electric vacuum pump located on the right fender well next to the starter relay and vacuum reservoir. This pump is always powered up with the key in any position and it is controlled by way of a built in vacuum sensor. It is not uncommon for them to just quit working. You can try smacking it with a screwdriver handle, check for voltage and ground at the connector or inspect the vacuum lines for breaks and disconnected lines. When the system loses vacuum, it defaults to the defrost position - the tell-tale sign of a complete loss of vacuum!
Old Jul 31, 2005 | 09:49 AM
Dieselhound
Thanks for the excellent tech info. If the fix involves whacking the part, spraying it with WD-40, volt checking it, replacing a hose or component, I can tackle it. One of my friends at work always says: If it isn't moving and should, spray Wd-40 on it. If it is moving and shouldn't, put duct tape on it;-). Nasa needs to use more duct tape on their shuttle.
Old Aug 3, 2005 | 09:40 PM
99FordGuy's Avatar
99FordGuy
I noticed the AC THUMP right away on my 05. It drove me nuts for a while but I've gotten used to it. Just turn the radio up loud and you can hardly hear it.
Also my wifes Navigator just started the AC out the defrost vent trick. It switches to the defrost vents for a few seconds and then back. I think it must have a vacuum leak or something.
jkidd_39
16
May 27, 2010 01:39 PM
judi48
Mar 14, 2008 07:14 AM
Dlinzy
Aug 8, 2006 09:47 PM
Raptorman
Feb 15, 2005 09:40 PM
1991rangerford
Offroad & 4x4
Jan 23, 2003 07:19 PM
