coil melted, causes?
Old Jul 29, 2005 | 06:40 AM
llh's Avatar
llh
pcm wire to pin 57 melted 2 weeks ago, replaced, now new coil melting, please help, possible causes?
Old Jul 29, 2005 | 10:42 AM
Bear River's Avatar
Bear River
Former ******
something is shorted out and causeing ecessive current through the coil. You will have to find where the short is. Check all nearby wires, and look for frayed wires and damaged connectors. Have a good ohm meter, and check the resistance between various points and ground. You will need a good wireing diagram. I recommend the Chiltons for this one.
Old Jul 29, 2005 | 03:52 PM
llh's Avatar
llh
we got this van used 6 mo ago. it was running on the wrong ign module(was for another car) do you know what damage that may have done. suspect this could be cause of slow developing problem. wires seem ok will start checking for shorts. any special areas in consideration of wrong module. have good meter, any info appreciated.
Old Jul 31, 2005 | 01:23 PM
Fordcr's Avatar
Fordcr
Where is RacerGuy when you need him or his friends?
Old Jul 31, 2005 | 02:48 PM
llh's Avatar
llh
Replaced Most Of Ign System, Checked Grounds, Connectors, Wires, Voltages,shorts, Open, Wiggle Test, Dark Visual Test, Still Have Miss And
Intermittent Short.checked Timing Spout Out, In ,10 To 26. Sprayed For Vacuum Leaks,etc,etc, Maybe A Fuel Injector Or Two Is Going Bad, Could This Short Back Into Dist And Ig Module? 146,000 Miles E350 Ford, No Codes In Computer Seems Connected To Those Cylinders? Is This Possible? New Coil Ok But Ig Control Module Went Again
Old Aug 1, 2005 | 12:43 PM
Bear River's Avatar
Bear River
Former ******
You may want to make sure your computer is ok.
Old Aug 1, 2005 | 01:29 PM
pfogle's Avatar
pfogle
The igntion modules are all the same regardless of vehicle. The big differences are in year, some were on the dizzy (pre 92), others on the fender or firewall (post 92). It sounds like a bad ground... Or a short on the PIP sensor wireing going into the distributor.
Old Aug 1, 2005 | 10:54 PM
Yakk's Avatar
Yakk
There are two different types of Ford ignition modules.
You can tell them apart by the color, either black or grey.
One type is called push start, the other is CCD(computer controlled dwell.)
-Jackson-
Old Aug 3, 2005 | 04:57 PM
llh's Avatar
llh
thanks for all the replys. took to diagnostic. it said ign is all running perfect. but one cylinder is dropping out and bubbles in radiator. could a cracked head or blown gasket be in any way related to the 3 weeks of crazy ign problems? did not overheat during this time.. compression test was not significant but bubbles come out every time it misses.
Old Aug 3, 2005 | 10:19 PM
pfogle's Avatar
pfogle
That sounds like a bad head gasket. Is it blowing white smoke?
Old Aug 4, 2005 | 10:32 AM
llh's Avatar
llh
no white smoke, pulled heads, oil in valley where intake seals ( dead space), assume must be cracked head?
Old Aug 4, 2005 | 12:33 PM
pfogle's Avatar
pfogle
Oil in the valley is pretty normal. Look at the gaskets carefully. They are more than likely the cause. Other than the light miss did it run well?
rockpile
Jul 26, 2016 12:28 AM
kunard333
1983 - 2012 Ranger & B-Series
18
Aug 24, 2014 11:17 PM
exlabman
May 31, 2014 10:56 AM
IHbase
Oct 5, 2013 07:51 PM
02sprdty
Oct 24, 2010 01:14 PM
