torque converter
Old Nov 14, 2002 | 10:12 AM
kts_fordman1's Avatar
kts_fordman1
Post torque converter
I have a 70 f100 390 bored, mild cam, holly 500 two barrel, 307 or 304 gears in the rear end. my question is what would be a good stall converter for me. I pull a trailer a lot, but i also like to rip around town and show the guys with new trucks that the oldies can hold their own. thanks.
also i have heard that FE stands for Franklin Edsel. does anyone else know more about that?
Old Nov 14, 2002 | 11:25 AM
joetee10's Avatar
joetee10
torque converter
I would reccomend that you keep the stock converter if you are going to tow alot. Stall converters generate more heat because they are designed to slip, and towing would only intensify the heat problem. Towing would also possibly damage the converter because it would slip even more until the converter fully engages.
Just my thoughts.
JOE
Old Nov 14, 2002 | 01:28 PM
dfisher1's Avatar
dfisher1
torque converter
KTS,
Joe has made a good point. A big stall does generate more heat.
BUT:
If your torque converter has a lockout, you can live with "this off the line heat generation." I am a firm believer in stall converters. They are great for developing bottom end range or, should i say, avoiding bad bottom end range.
A 2400 holeshot with lockout could work for you. Get some advice from a tranny specialist or a tow truck company. Towing will be your downfall, not racing. But, there is no better way to get out of the hole quickly than using a big stall converter.
Consider it,
KingFisher
Old Nov 14, 2002 | 09:41 PM
LxMan1's Avatar
LxMan1
torque converter
B&M makes a convertor just for towing. Check them out. Personally, I would switch to a 3.50 gear.
Old Nov 15, 2002 | 05:01 AM
doc_f250's Avatar
doc_f250
torque converter
GreatNorthWoods
Apr 21, 2015 07:30 PM
less
Jun 16, 2008 11:39 PM
edselranger59
21
Jun 25, 2004 10:41 AM
Franklin2
Dec 25, 2001 10:50 PM
hpflowman
May 26, 2001 08:25 PM
