Outside Temp. Reset
Jul 27, 2005 | 11:20 PM
Outside Temp. Reset
I have a '03 F250 and the overhead console temp. is stuck at -40. How do can I reset it. Please Help!
Reason: More Information
Jul 28, 2005 | 05:01 AM
Jul 28, 2005 | 06:43 PM
You can try disconnecting the batttey for 10-15 min. but most likely its the temp sensor. It's under the radiator cover
Jul 28, 2005 | 06:50 PM
Thread moved to Super Duty forum.
-Matt
Jul 28, 2005 | 10:21 PM
Thanks I will try that. What a great site!
Jul 29, 2005 | 08:10 AM
After four years of reading posts about SuperDutys, that's the first one like that!
Jul 29, 2005 | 10:57 AM
On the same topic....
I thought I read somewhere on here that there was
a way to adjust the reading by +/- 4 deg or so???
Was I dreaming???
Chris..
Jul 30, 2005 | 02:35 PM
haven't heard of this. The reading is probably within +/- 4 deg of the actual temp.
Jul 30, 2005 | 02:51 PM
Temp Readout
If your temp readout is stuck on -40, that usually indicates an open somewhere in the circuitry or the sensor is open.
RON
Aug 4, 2005 | 10:28 PM
Well I tried disconnecting the battery. That did not work. Back on July 4th I was in a fender bender. I was hit on the left front side of my truck. I am thinking that the body shop did not hook the sensor back up when they replaced parts on the front end.
sgtscrounge
Mar 6, 2014 06:37 PM
ssg510
Aug 5, 2012 12:56 AM
chopperpilot
1997 - 2003 F150
Mar 22, 2008 08:27 AM
amberamber
Nov 9, 2005 06:56 PM
gunslinger67
1983 - 2012 Ranger & B-Series
Sep 12, 2004 10:03 AM
2005 ,
ext ,
exterior ,
external ,
f150 ,
f250 ,
ford ,
reset ,
sensor ,
superduty ,
temp ,
temperature
