Sponsored by: Auxito
reset after a crash
Old Mar 21, 2008 | 10:29 AM
chopperpilot's Avatar
chopperpilot
reset after a crash
What and where is the reset button for the inertia switch, I see a box under the passenger side panel. but I can't find the reset.
Old Mar 21, 2008 | 10:35 AM
chopperpilot
Forgot to mention the year
The truck is a 98, with a 6 cyl. 4.2, it was a hit and run and now I am walking
Old Mar 21, 2008 | 10:44 AM
Bobby82490's Avatar
Bobby82490
I know it is in the passenger side kickpanel, maybe unplug it then plug it back in? Normally there is a button on it, but it has been a while since i have looked at mine.
Old Mar 21, 2008 | 10:54 AM
wolfman01's Avatar
wolfman01
The button is on top of the box. You pretty much reach it by feel.
Old Mar 21, 2008 | 11:15 AM
chopperpilot
thanks bobby, wolfman...I feel but there is no reset, i disconnect both harness and nothing...what other way can I find out if my pump is working, I disconnected the line and turn the key on and nothing comes out?
Old Mar 21, 2008 | 11:29 AM
wolfman01's Avatar
wolfman01
Your reset switch should be identical to mine. When you feel up along the top of the box, you should feel a circle up top. The switch is recessed inside that circular spot, and it's one of those switches where it barely moves, but you can feel the "click" of it depressing. If you still have your owner's manual, it will show you a picture of this switch.
Old Mar 21, 2008 | 11:37 AM
chopperpilot
I found it!!, it was down, I pulled it up and press it sown again and no fuel still, which one is the fuel pump relay or where is it located>
thanks man
Old Mar 21, 2008 | 11:42 AM
wolfman01's Avatar
wolfman01
Fuel pump relay is under the hood. I do not recall which slot it sits in.
Old Mar 21, 2008 | 12:05 PM
Club Wagon's Avatar
Club Wagon
Never heard of pulling it up, only pushing a 'popped' fuel pump 'rollover' switch to restore power. Be sure it is pushed down fully & reset.
thanks man
There's 6 relays in a row next to the fuses by the master cylinder. The fuel pump relay is essentially the center 1. Its the 3rd inside square relay next to 3 rectangular ones.
Old Mar 21, 2008 | 12:26 PM
chopperpilot
Thanks Club Wagon, found it, pulled it out and swhitched with another sameone and with the key turned on, the relay in a different slot clicks as its being activated but when I placed the relay on the fuel pump slot, nothing happens?????...I am getting 12v to the slots on the fuel pump relay but something is preventing it from energizing...would you know what it might be? its driving me nuts
Old Mar 21, 2008 | 01:10 PM
Spotty's Avatar
Spotty
Check your fuses... Fuel pump Relay, fuse #19... 20 amp... under the hood... mine is a 98 also, but with 4.6.... your fuse location may be different.
Spotty
Old Mar 22, 2008 | 08:27 AM
Moore FOMOCO's Avatar
Moore FOMOCO
The Delta-P should be popped "up." Push down to reset, if it is not popped-up then it is not the issue.
vetteman04
6.7L Power Stroke Diesel
Jun 30, 2017 01:28 PM
ssmandavid
Feb 4, 2016 08:35 AM
JosephDunivan
Aug 22, 2015 05:57 AM
Glenn Blackwell
Aug 6, 2014 05:15 AM
brucememp
13
Dec 28, 2004 02:00 PM
