glow plug timer problems!
Old Nov 7, 2005 | 06:19 PM
amberamber's Avatar
amberamber
<HR style="COLOR: #666666" SIZE=1>
Ok, the glow plugs are fine, but the timer or perhaps the temp sensors on the timer are not accurate. is there a way to test the sensors or reset them, or do i have to buy a new starter?
amber
Old Nov 7, 2005 | 07:18 PM
Dave Sponaugle's Avatar
Dave Sponaugle
amberamber, what year is your truck?
Old Nov 9, 2005 | 05:47 PM
amberamber's Avatar
amberamber
ford truck
93 f250 deisel, 4x4 standard
Old Nov 9, 2005 | 06:56 PM
Dave Sponaugle
The 93 system uses resistance feed back from the glow plugs to set the time they heat.
How long are they heating?
Have you checked all the connections for corrosion?
How are you checking the glow plugs?
The black wire on the controller needs a good ground for it to work right. That is a common problem.
Near the dip stick is a connector that the engine harness plugs into the truck harness at. Pull it apart and check for corrosion on the terminals and check it for signs of overheating. The battery power to the relay/controller goes through that connector as well as ignition power to the IP and glow plug relay to start the timing cycle.
Also check all the connections near the passenger side battery for good contact, that is where the battery power to everything comes from.
bobv60
May 19, 2019 05:33 PM
fourplay
2015 - 2020 F150
Dec 3, 2015 04:09 PM
AVL1955
Mar 27, 2015 09:44 AM
lewis racing
Feb 19, 2015 11:55 PM
ithaca1230
Feb 19, 2014 08:52 PM
