Lean on Bank 2 only
Old Jul 26, 2005 | 05:36 PM
dphill's Avatar
dphill
Lean on Bank 2 only
Getting a PO174 error with check engine light on in '97 Expedition. Have replaced fuel filter, replaced both O2 sensors up from cat's, replaced intake manifold gaskets, checked gas pressure, 30-42 psi.
PCV line and elbows appear to be fine.
111,000 miles, problem surfaced at around 90,000, no driveablility issues, just an annoying light.
Thanks,
Old Jul 26, 2005 | 06:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 26, 2005 | 08:56 PM
2Fords1Jeep's Avatar
2Fords1Jeep
Have you checked the MAF sensor?
Old Jul 26, 2005 | 11:13 PM
dphill's Avatar
dphill
Haven't checked the MAF yet. Wouldn't that affect both banks and trip both codes?
Thanks for the ideas!
Old Jul 27, 2005 | 05:54 PM
dphill's Avatar
dphill
Cleaned MAS as per other posts on this forum. Reset the computer and went for a drive. Seems to have worked.
Thanks,
Old Jul 27, 2005 | 09:48 PM
FTE Herman's Avatar
FTE Herman
I just got done clearing the code for the second time. I'm just a shade under 90K. If I figure it out, I'll let you know.
Old Jul 28, 2005 | 04:36 AM
2005Mariner's Avatar
2005Mariner
Question Fuel injectors...
You may have an injector that is going bad and leaning out a cylinder? Have you tried running some cleaner through them? If you pulled the plugs, were any of them white in color, which tends to indicate a lean condition. Are you experiencing any detonation (pinging)? Running lean is a bad thing, that could cause an engine failure. Hope it is something minor.
Old Jul 28, 2005 | 10:53 AM
dphill's Avatar
dphill
Plugs were fine, visual of injectors looked fine during the intake gasket replacement. Have run cleaner through as well.
Thanks
Old Jul 28, 2005 | 03:16 PM
Sanchez_315er's Avatar
Sanchez_315er
Did you get this error before or after the intake gaskets?
Old Jul 28, 2005 | 04:44 PM
dphill's Avatar
dphill
Before the intake gaskets. Had the error for about 20,000 miles. Doesn't affect drivability at all. Mileage is a little lower but that's it. We listed for vacuum leaks and heard a faint leak in the intake area. The gaskets were starting to separate (a common problem I've heard) but no major blow outs. Bolted it back together and the code came back. Since then I've replaced the pvc line and valve and cleaned the MAS and cleared the codes. Code has not shown back up.
Dave 1998
Nov 30, 2011 02:50 PM
b270csm
Jun 1, 2010 09:46 PM
whitecougar
1997 - 2003 F150
Jun 21, 2007 08:00 PM
gmaire
1997 - 2003 F150
Oct 27, 2003 08:42 PM
blau87
Dec 31, 2001 08:13 AM
