CHECK ENGINE LIGHT ON
Old Jun 1, 2010 | 08:59 PM
b270csm's Avatar
b270csm
1996 ford F-150 302 170,000 miles. Check engine light is on. Active code P0171 and P0174. Left bank and right bank lean. Runs good, only gets 8.5 miles per gallon. Truck has been to Ford dealer twice for same complaint. Mass air flow sensor has been replaced, o2 sensor at cat has been replaced, and all eight fuel injectors have been replaced. Check engine light is still on. Ford dealer won’t return phone calls. Can anyone tell me what could be wrong?
Old Jun 1, 2010 | 09:11 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Check Fuel pressure at the rail. Do you have a CAI mod?
Old Jun 1, 2010 | 09:27 PM
b270csm's Avatar
b270csm
what is a cai mod ?
Old Jun 1, 2010 | 09:30 PM
b270csm's Avatar
b270csm
yes it has a k&n fipk kit has been on truck for ten year maybe give or take
Old Jun 1, 2010 | 09:46 PM
ymeski56's Avatar
ymeski56
Der Postmeister
They tend to lean out a MAP engine, but not so much for MAF. It has to be too much air or not enough fuel ............or an unmetered air source. Like a leaking air intake manifold. Like the gasket. Sometimes the mount bolts loosen up! warm curb idle around 650 rpm or elevated?
sjniii
1983 - 2012 Ranger & B-Series
42
Jul 29, 2024 06:05 PM
Teager
Mar 28, 2024 11:44 PM
firefighter6783
Jun 24, 2013 12:55 PM
Bear13861
1997 - 2003 F150
Jul 6, 2011 02:23 PM
Lugnut2008
Modular V8 (4.6L, 5.4L)
Nov 9, 2007 01:57 PM
