small block c6 tranny?
Old Nov 20, 2002 | 09:35 PM
cjben's Avatar
cjben
did ford make a c6 (2wheel drive) with the 302/351w bolt pattern, and if so, what vehicles had them? how hard would this swap be into my 1978 f100 with a c4? The c4 needs rebuilt, so I am thinking if I can find a c6 and rebuild it, i would be a step ahead when I start modifying the engine for more power. thanks, Ben
Old Nov 20, 2002 | 09:49 PM
tetraruby's Avatar
tetraruby
I don't know all the things you'd need to swap, but the C4 is shorter - you'd need to have the drive shaft shortened. The C6 will also rob a few extra ponies compared to the C4 also....but it's supposed to be bullet proof.
Old Nov 20, 2002 | 09:57 PM
kennethl6's Avatar
kennethl6
Vans from the mid 70's on and F150-250 in the 80's with 302,351 or 300-6's without AOD's should have small block bolt pattern C6's.
Old Nov 20, 2002 | 10:32 PM
Mike W's Avatar
Mike W
I have a 69 Mustang with one.
Old Nov 20, 2002 | 10:39 PM
Quadiquizm's Avatar
Quadiquizm
YUP - C6 is definately a strong tranny. Does steal HP and MPG, but they do seem to work well. If you plan on adding HP, then I would reccommend a C6.
I have a 302 bolted to my C6 in my 1979 F-150.
I've also got a 351M bolted to a C6 in my parts truck.
I hope this answers your questions.
Keep it Rubber Side Down!
Old Nov 21, 2002 | 12:22 PM
Ford_Six's Avatar
Ford_Six
I swinging a c6 in behind the 351c I just dropped into my F-250, and I have access to a van with a 300-6 and a c6. Want it?
Jared
Old Nov 21, 2002 | 01:36 PM
cjben's Avatar
cjben
Jared, I might be interested. where are u from?...thanks, Ben
Old Nov 21, 2002 | 06:17 PM
theonlybull's Avatar
theonlybull
i've got a c-6 with the sb bolt pattern that i'd like to sell. $100 canadian.. but shipping would probably kill ya.... did some of the c-4's have longer tail shafts, or output yokes? my 79 had the c-6, and my 78 had the c-4, but the drive shafts were the same length..
Old Nov 21, 2002 | 07:43 PM
ford4life69's Avatar
ford4life69
I learned the hard way that they did put the 302 out with a C6 behind it if you ordered it that way. My 79 is a 302/C6 combo. I made the mistake of reading my engine book that said 302's came with c4's and then proceeded to put type F into a C6 that doesn't use type F fluid. The Hayne's manual for my 79 Ford says that 302's came with c4's (but now I know.....) and 351's came with c6's. Don't know that that'll help any more than what's already been said but thought I'd throw my 2¢ in.
Thanx!
Connie (only Ford luvr in the family!)
'79 f100 "Silver Ghost" (my baby)
'83 f100 "The Ford" (my first)
'85 f150 "Old Blue" (my next project)
Old Nov 21, 2002 | 10:40 PM
Ford_Six's Avatar
Ford_Six
cjben
Jan 10, 2005 12:20 AM
cjben
Feb 25, 2003 07:46 PM
cjben
Jan 5, 2003 04:20 PM
cjben
Apr 1, 2002 11:07 PM
cjben
Jun 1, 2001 04:58 PM
