Sponsored by: Auxito
Transfer Case stuck
Old Jul 26, 2005 | 08:58 AM
yanyika's Avatar
yanyika
Transfer Case stuck
To those interested.
Bought a used 1998 Ford F150, AT, 4WD manual (floor shifter), 4.6 V8, Scab with 145K miles. It came from utility company.
Engine sounded OK, tranny shifted fine. 4WD light came on when turned on etc. It was in 2WD when is test drove it.
Several days later at home I tried to gett in 4WD and the shifter wouldn’t budge, either with engine off or on-the-fly. I thought the transfer case was busted. I started kicking myself for not checking it out. I needed the 4WD for the winter in PA and the Scab for new baby (seat). {Got rid of my 1992 F150 Flareside XLT (a beauty), regular cab, 2WD etc}
<O
Anyways, took it to a shop I can trust and the guy told there was no major problem. The transfer case was stuck because of lack of use. $75 for the clean-up. Now the transfer case is working fine. But – I have to be in Park, engine off to shift between 4WD(hi-lo)-2WD etc. this is suppose to be shift on the Fly. When I try to S-O-F (2WD-4WD-2WD) I hear a sound like clutch grinding.
Any ideas?? Should I check the oil in the Transfer case/Diff etc?? Will that be the problem.?
<O</O
It is a very nice truck – but two other problems I noticed. First, ticking/pinging noise during acceleration but not at idle or cruising speed, it is more noticeable when the engine is cold. Also that “thud” on take-off from a stop. Feels like something is loose.
<O
Any ideas??
<O></O>
Thanks
Old Jul 26, 2005 | 12:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The grinding you hear when trying to go to 4x4 is the front-driveshaft not spinning up.
I don't know much about F150's, but do you have manual locking hubs, or are they the rachet style without a **** on them?
Could be that the front driveshaft u-joints, diff, hubs, etc, are dirty/stuck enough that when running, the front driveshaft doesn't spin up fast enough, and you get the grinding noise.
I would use 4x4 for a little while, doing whatever you need to do to get it in 4x4 in the first place and work out some of the front driveline to see if it loosens up.
Old Jul 26, 2005 | 12:43 PM
kingfish51's Avatar
kingfish51
With the floor shifter, I have always got a little noise when shifting between 2wd and 4wdhi. You do have to be in neutral, foot on brake to shift between 4hi and 4lo.
You do not have front hubs. At the wheel are CV joints and lock up is done at the transfer case and front diff. Diff is locked by vacuum.
As I said, all my MSOF have made some noise for me.
Old Jul 26, 2005 | 02:01 PM
yanyika's Avatar
yanyika
Thanks. Hope there is no damage.
Old Jul 26, 2005 | 08:41 PM
V10F250's Avatar
V10F250
I would start with checking the fluid level. Never hurts to do that. However, if it continues to grind, I would take the truck back to the shop and talk to them. I would bet that they did not clean the 4wd good enough.
Lowe
Jul 12, 2012 01:53 PM
jpj64
1983 - 2012 Ranger & B-Series
25
May 24, 2010 08:58 PM
jeff2011
Sep 7, 2009 10:54 PM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
Technocrsr
Feb 17, 2007 09:13 AM
