Prodigy brake controller problem
Old Jul 25, 2005 | 08:30 PM
pmc123's Avatar
pmc123
I have a 99 e 150 with factory tow.
When I plug my prodigy controller in right turn signal goes on, no power to controller.
I know the controller works I took off my 99 expy
Any Ideas???
Thanks
Old Jul 25, 2005 | 09:41 PM
220k-f-150's Avatar
220k-f-150
Not sure.Could be a ground wire. But no power to the plug for the controller is probably a fuse. Could be a possible short somewhere. Since it worked in EXPY I'd say its in the van wiring some where.
You might check down below in the other forums for towing, trailers, etc. or possibly a moderator could move this post for you to there.
Old Jul 25, 2005 | 11:21 PM
smoothhopperator's Avatar
smoothhopperator
ok so i had spark knock problems seperated the 7 and 8 plug wires not that timeing is correct good thick wires still did it then i replaced the tfi its gone which is good but now when its in the higher rpms its starts freaking out the tach starts jumpin around the engine sounds like its missing horribly when it occurs it occures in the rpm range of 3500 to 4000 didnt do it before i put the new module in dont want to put the old one back in it will start spark knockin again any help is greatly thanked this problem with my igniton just wont go away fix one thing another weird thing comes along
Old Jul 26, 2005 | 06:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome smoothhopperator, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
erba
Aug 17, 2021 07:17 PM
F2250crew
Oct 21, 2014 04:39 PM
beeser
Nov 8, 2013 05:14 PM
StevieD6262
Aug 6, 2013 08:56 PM
slantfin
All Things Towing
Feb 8, 2005 06:33 PM
