cab corners :(
Old Jul 26, 2005 | 12:05 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
Two heaters were available. One was a recirculating heater that simply heated the air in the cab. The other was a fresh air heater that had ductwork to that outside vent that could be opened to pull fresh air in from outside.
Kevin
1953 Ford F-100
Go Illini
Old Jul 26, 2005 | 12:12 PM
Earl's Avatar
Earl
Kevin has it. The block-off plate is what you got if you didn't get the fresh-air option package. My F-250 has the block-off plate as well.
Old Jul 26, 2005 | 12:17 PM
AXracer's Avatar
AXracer
My side cowl vent had a cover over it I assumed the PO put on it when they put in the AC unit. I'm considering adding a duct to an outlet on the kick panel for when I want fresh air and it is raining too hard to open the cowl vent. I vaguely remember a car my family had, I think it was the 54 Ford SW, that had a door on the heater that you could open for fresh air.
Old Jul 26, 2005 | 12:37 PM
sdetweil's Avatar
sdetweil
Thanks for all that great info!.. now I need to look at my future heat & A/C chocies to see if they use this vent or not.. at least BEFORE I weld it shut!..
lucky timing.. am doing bodywork now!..
Sam
Old Jul 26, 2005 | 12:51 PM
fordgo's Avatar
fordgo
so do i the one mine came with was plumbed straight to the engine with no way to regulate the temp or to turn the defrost off so it was either off or cremate lol kinda reminde me of the helos i was flying in at the time it had a 500,00 btu heater in it the pilots would get toasty in the cockpit and i would have to open up the windows in the back when it was on or burn up !!!
F100man
Jun 12, 2013 07:20 AM
jpcnorthwood
Appearance & Dress-Up
Jul 13, 2009 07:21 PM
reamer
19
Dec 12, 2005 02:06 PM
chieff
Paint & Bodywork
Feb 23, 2004 03:15 AM
78bigunns
Oct 14, 2001 11:45 AM
