10 Minute Cab Corner Die
Old Dec 7, 2005 | 07:22 PM
reamer's Avatar
reamer
I put a photo of the cab corner I made in my gallery "cab corner".
I may make the Die in steel now and make a bunch of "correct" corners.
Anyone interested?
Reamer
Old Dec 7, 2005 | 11:16 PM
CIAF's Avatar
CIAF
Are you talking a hardened steel compound or progressive die ?? How big of a drop hammer do you have ?? Last time I bought a similar die it cost 84 thousand dollars. You could just get the corners done by somebody with a wheel ( english ) for an affordable price. There is a guy in Denver that can duplicate anything in metal that specializes in Fords and ****** trucks. Just a thought along with curiosity.
Old Dec 7, 2005 | 11:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The die is plywood, isn't it?
Old Dec 7, 2005 | 11:35 PM
CIAF's Avatar
CIAF
Some are. The Nastruck builder (Just Dreamin', Denver) used a plywood "buck" to build the headlight pods for using the Mini light in the fenders. That was also a reversible buck that was taken apart and re-assembled in reverse to use on the right side. ( the truck was awsome, I saw it Thanksgiving weekend)
Old Dec 7, 2005 | 11:39 PM
51ford fan's Avatar
51ford fan
Nice job making those cab corners what year are they for
Old Dec 8, 2005 | 05:55 AM
49willard's Avatar
49willard
Anyone interested?
Reamer
Reamer,
Nice job on the cab corner!
Old Dec 8, 2005 | 07:52 AM
bobj49f2's Avatar
bobj49f2
I stumbled on this site quite a while ago:
http://www.heritagesonline.homestead.com/index.html
Click on the metal working buttons. He shows how he formed widow frames and complete doors for his Divco trucks. These are basically the same shapes needed to from the corners and many other pieces of sheet metal. He uses tools that many us can get our hands on, no major production machinery like 20 ton presses and CNC machines. I found it very interesting and when I get the time I am going to try to reproduce some parts using his techique.
Old Dec 8, 2005 | 08:03 AM
reamer's Avatar
reamer
The cab corner I made is for my '48. The wood die is solid oak. I can easily make it now with "sandwiched" plate steel and a big F#$%)* mallett.
Old Dec 8, 2005 | 08:37 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Reamer,
Nicely done!! Don't ever let them tell you that you can't do something
Bobby
Old Dec 8, 2005 | 08:03 PM
g84t8f1's Avatar
g84t8f1
Nice job.Looks like it should.
ART
Old Dec 8, 2005 | 09:40 PM
nixer's Avatar
nixer
i plan on doing this out of metal for some small areas for my firewall
Old Dec 9, 2005 | 12:58 PM
fatfenders56's Avatar
fatfenders56
Good job! You guys may want to check the article in the new Street Rodder on forming corners
Old Dec 10, 2005 | 11:30 AM
AXracer's Avatar
AXracer
Looks like your bends are now sharper than OEM. Still have to form the outside curve (would probably been easier to shrink it while tightening the bends).
I make hammerforms from MDO much cheaper and easier to shape and they will last thru several uses.
Old Dec 10, 2005 | 06:15 PM
reamer's Avatar
reamer
Yeah, I haven't routered the radius yet, Got to get a bit for that. But since its 20 degrees out, I figure Iv'e got about 16 weeks to find "the perfect one!"
Old Dec 10, 2005 | 08:07 PM
AXracer's Avatar
AXracer
Small radius router bits are hard to come by. I have found 1/4" but nothing smaller you may need to just sand off the corner by hand or make a steel scraper. It doesn't need to be absolutely perfect, the metal will bridge any small imperfections, but remember the outside radius of the metal will be larger than the radius on your hammerform. If you are interested I can give you some suggestions on building a die that will form the entire piece.
