Glove Box Installation???
Old Jul 23, 2005 | 12:29 PM
Bill'sBoy's Avatar
Bill'sBoy
Reworking most of my interior. I tried searching, but couldn't find any details. I did find out that it has to be installed from behind. Do I have to remove the dash in order to install the glove box? The old one was broken, so I smashed it to remove it, obviously the other one won't go in the same way. Any tips will be helpful. And if I have to remove the dash, how big of a job is it? I'm planning on installing a new radio as well and rewiring, so should I just remove the dash anyway? Thanks for all the help.
Old Jul 23, 2005 | 03:19 PM
T18skyguy's Avatar
T18skyguy
On the toolbar on the top menu click the articles button then the search button and type in glove box-there is an article called Everlasting steel glove box that's really good.
Old Jul 23, 2005 | 04:33 PM
plowpusher's Avatar
plowpusher
do you have air ? i just put a glove box into a 77 w/o air you can just push it through the opening carfully and mount it or yuo can push it by the heater and wiggle it by but it's 6 of one 1/2 dozen of the other as for the radio depending on it's size you can pull the gauge cluster and get it in that way or slide it through the glove box hole
Old Jul 23, 2005 | 05:51 PM
progt1's Avatar
progt1
I bought one of the plastic glove boxes form JBG. I removed the glove box door and pushed it through the opening. The air conditioning didn't get in the way. In fact the ductwork helped hold it while I applied the original screws.
Old Aug 1, 2005 | 09:22 AM
cigarxtc's Avatar
cigarxtc
For my '78 with Factory A/C, I had to remove the lower right air duct to put my 'Everlasting Metal Glovebox' in from behind.
Old Aug 1, 2005 | 09:41 AM
dakonthemountain's Avatar
dakonthemountain
In my 77 with air I pushed it (the cardboard one.. and NOS) through the opening and ripped it!!!!! so I had to start over, bought a new one and removed the AC vents under the dash and anything else (heater hose, etc.) that was in the way. It was a pain!
Dak
Old Mar 15, 2025 | 09:35 PM
Indie's Avatar
Indie
Nitemare on1984 non air mdl...Purchased a replacement That looks like a waste..No way it's going in without some major disassembly..I will have to make a half box. Make up a few prototypes from coca cola cardboard. Buy some black chipboard from MICHAELS ART later maybe when get a useable pattern completed .I am not taking all that stuff apart over something that should go right in like a 64 Chevelle or 68 Camaro..Only half of the box has enough depth to hold anything.The other end is so shallow it will barely hold an envelope standing on edge..Not trying for a perfect restoration..If you fix it up too good you can't drive it.. I don't hang with eccentric millionaires ready to pay $30k or $60k..
Old Mar 15, 2025 | 11:49 PM
tbear853's Avatar
tbear853
My OEM was OK on sides and top, but the floor was not great, and had a hole. I made a carboard template fit the bottom as perfect as I could get it, then took a piece of the same carpet fibers bonded in a rubber base like used in my floor, etc ... cut to the template, it is about a perfect fit. Was gonna use thin luan plywood, but like this better. No holes, sturdy.
Old Mar 16, 2025 | 06:31 AM
Indie's Avatar
Indie
​​​​​​ yes.. Cardboard templates.Thin stuff like coca cola cartons...The black chipboard in larger sheets not that easy to get shipped to you .But packaging cardboard, wood glue will get you something to work with. Can double layer it..Plenty of ways to strengthen it . The screen dry wall tape may stick a little. Putty knife liquid nails over that ( on the outside , no one will see it ) ..Let it dry , that's some strong stuff . Fiberglassing cardboard might be too wet.. it's a simple ARTS & CRAFTS project. But cardboard can make a great glove box..You can improvise and have a nice finished product..That will fit without having to dismantle half the dash .Can fit a separate panel in on the defrost blower side. ( On the 1984 non- ac model ) Not much storage there on the factory box anyway...The cool thing about making your own parts ..It won't be original and thieves won't be looting parts...In many cases your part will out last the factory part and is superior...
Old Mar 16, 2025 | 09:56 AM
tbear853's Avatar
tbear853
I know that often the originals give up after being over stuffed or getting wet from a spill at the local "Curb Service Burger Doodle" (like when the server skates by in those slacks, maybe driver turns head, maybe date/wife smacks him playfully, and knocks her coke what was standing on the opened door over into glovebox on top of stuff) or the "Rocket Love Drive In Movie" theater(???), etc.
When I put buckets w armrests in from a Mercury Grand Marquis so many years ago, a 4" wide space was left between the seats (they touched each other when in the donor car), but it's like over 8" deep, over a foot long of "free space". I built a box of wood, matches the seat taper, bolts to the floor with 1 bolt, removable lid with hidden latch that is nothing more than a 1/4" pin, and included two SS cup holders. For years, just painted black but now covered with textured black vinyl. I have registration, insurance papers, owner manual, maintenance records, etc in it ... so none of that stuff has to be in the glove box. I might even have a map in there. Somebody opening my glove box might find a yellow see through pill bottle with quarters for a car wash, a couple drink straws, a little glass jar with extra fuses, a pair of thin leather gloves, a pencil and a good ink pen, a small note pad too, but not much else.
NO ketchup, mustard, or salt packets.
Any tissues, sanitizer, screw drivers, etc .... they have door pockets .... and there is behind seat storage too.
Old Mar 16, 2025 | 10:03 AM
Viper Pilot's Avatar
Viper Pilot
Another option is to just buy a molded plastic one and save yourself the hassle. $37.
https://www.npdlink.com/product/glov...1973&year=1973
ranger140892
Jul 3, 2019 09:50 PM
purecty
Mar 29, 2012 09:11 AM
Nobby
17
Jan 2, 2012 02:29 PM
steve m
May 12, 2005 09:12 AM
elliott
Feb 5, 2004 02:20 PM
