Glove box
Old Jun 28, 2019 | 11:37 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Glove box
Here's a bonehead question: What's the procedure for installing a glove box? I've been without one for too long. I ordered a plastic box from JBG a couple of years ago, but they never got them in stock. I'll settle for the factory type. Please tell me I don't have to remove the dash board or front panel. Thanks, Guys.
Old Jun 29, 2019 | 06:57 AM
73GreenBean's Avatar
73GreenBean
If I remember right I slid my cardboard type up under the dash but I can't remember if I had my heater and fan assembly still under there at the time. I know it takes some patience and it's goes in at a weird angle but if you're careful you should be able to bend and pry a little at a time without ripping the cardboard. Good luck
Old Jun 29, 2019 | 09:04 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
A/C truck? Is sort of a PITA with less room, none a/c... a little less a PITA. lol Yes just carefully slide/slip/push/maneuver it up from under and behind the dash. Careful, because the pressed glove box dash hole on the dash can have some sharp edges. Especially the L and R short edge ones. Do you have a L/H side glove box light? Get it out of the way before hand. They come out easier than they go in.
Old Jun 29, 2019 | 10:23 AM
NiagaraFord's Avatar
NiagaraFord
Take your time, I’ve destroyed three glove boxes trying to install them 🤷🏻*♂️
Old Jun 29, 2019 | 11:11 AM
ranger140892
Grumpy goat
Thank you very much, Gentlemen.
Mine is non A/C, so should be a little easier. I wish I had done this when I changed the heater core.
Old Jun 29, 2019 | 11:31 PM
Redrokin09's Avatar
Redrokin09
Mine has A/C and they're easy to get in and out. Make sure you remove the limit strap cable, remove the uper latch. Go in at an angle with your right hand in first and then feed it through. It super easy.
Old Jun 30, 2019 | 10:02 AM
ranger140892
Grumpy goat
Thanks, Redrokin09.
Old Jun 30, 2019 | 09:46 PM
John89's Avatar
John89
Did ours today.
Took door completely off.
Removed top latch.
Fed it through the front, then worked it into place once it went through. I wasn't going to try to go in from the back, it just didn't seem like it would go.
Had to give it some gentle nudges to get it to go through the opening.
10 minute job.
Ours is non AC.
Old Jun 30, 2019 | 09:50 PM
ranger140892
Grumpy goat
Thanks, John. I'll order one from LMC or some place tonight before bed. Thanks to all you guys.
Old Jun 30, 2019 | 11:06 PM
maddogjohnson's Avatar
maddogjohnson
I just installed my glovebox a few days ago. I did it from underneath on my A/C truck. It wasn't too hard to do. I did have to pull out the A/C duct to get the glovebox up in there. My A/C duct needed to be cleaned out before reassembly so that was part of the reason I did it that way. It was just a matter of getting the right angle in moving the glovebox around once I got it up in the right area and then getting the right angles on the A/C duct to get it to all fit where it should. I did have one under dash electrical connection I had to unhook and move out of the way while installing the glovebox. I'm not sure what it's for.
w/o A/C I'm sure it's easier.
Old Jul 3, 2019 | 04:25 PM
ranger140892
Grumpy goat
I just installed my cardboard glove box. Just for s&g's, I slid it in from the front and from the rear to see which is easier. It was easier from the front. Thanks, Guys!
Old Jul 3, 2019 | 09:21 PM
hail destroyer's Avatar
hail destroyer
Whats the problem? mine practically fell out. 😁
Old Jul 3, 2019 | 09:50 PM
ranger140892
Grumpy goat
Dammit! All those other guys gave me erroneous info. Your way would make it much easier to get that top left screw to thread up. Next time I'll PM you.
Bill'sBoy
Mar 16, 2025 10:03 AM
purecty
Mar 29, 2012 09:11 AM
Aaron-71
13
Oct 31, 2011 10:16 PM
cwgu3
Aug 5, 2011 04:30 PM
steve m
May 12, 2005 09:12 AM
