Glove box
Old Jan 12, 2004 | 08:52 PM
elliott's Avatar
elliott
Glove box
Can anyone tell me how to get a new glove box (cardboard?) into place without tearing it up? Thanks, Bob
Old Jan 12, 2004 | 08:57 PM
Mil1ion's Avatar
Mil1ion
Remove the heater box first.
If that doesn't work,
You will have to bend it ever so lightly to Push & scrape it into position,
Old Jan 13, 2004 | 01:40 AM
GeneStoner's Avatar
GeneStoner
I covered the exterior of mine with metal tape (for use in HVAC applications) prior to re-install. It didn't make it any easier to install per se, but it should keep the somewhat flimsy unit from deteriorating prematurely...
Old Jan 13, 2004 | 12:47 PM
bigredtruck's Avatar
bigredtruck
I fiberglassed the outside of mine, undercoated the inside, then had to wait a few months to drop the heater to get it in.
So, unless you can squeeze it through the opening with luck and not tear it, it looks like from under the dash is the easiest way.
Old Jan 13, 2004 | 01:48 PM
biz4two's Avatar
biz4two
I was pretty successful installing from the front. I did remove the glove box door and it was about 95 degrees out. That I am sure helped some.
Old Jan 26, 2004 | 11:25 AM
jbird's Avatar
jbird
Smile replacement glove box
go to this address for a plastic glove box that you can install through the opening very simplyhttp://broncograveyard.com/products/...love%20box&sy=
Old Jan 28, 2004 | 07:07 AM
classyfish's Avatar
classyfish
Take the door off, but also the latching mechanism on the top inside of the opening . Its held by 2 screws and pushes off with a little force. Then you can (massage) the box in easily, just dont force it. Cardboard is flexible, just me careful.
Old Jan 28, 2004 | 12:39 PM
beartracks's Avatar
beartracks
Turn it sideways and push one end in first. I used the plastic one and it's good.
Old Feb 5, 2004 | 01:06 PM
cigarxtc's Avatar
cigarxtc
Check out the FTE Tech Articles. There's a new article on there, that might provide you with what you're looking for. When I get the free time, I make them and put them up on Ebay. If ya need help or have questions about the process then lemme know. If any of you local people need help lemme know. I've got all the metal working tools in my garage to make these.
Old Feb 5, 2004 | 02:20 PM
pro3qtr's Avatar
pro3qtr
I got a new one from the dealer.
Have not installed it yet.
