6.0 High Idle Question
Old Oct 19, 2005 | 06:18 PM
  #31
big ride's Avatar
big ride
wiring woes resolved
For all those w/ 6-speeds, and wanting an increase in idle speed... here you go. I did this, and it works!!!! YIPPEE!!
http://flatratetech.com/cgi-bin/ubbc...c/29/1638.html
(Hope this helps), if need be, and can look at mine for exact coloring again, ENJOY!
Old Oct 19, 2005 | 07:09 PM
  #32
Betaracer's Avatar
Betaracer
Tried to do it with my 04 6.0PSD 6spd manual. No go with the same wires used with an automatic equipped truck. Tried the resistor. I wonder if there is a different wire to connect with the manual than with the auto. 04 wire colours are different than the 05, so the 05 instructions don't help me. thanks
Old Oct 25, 2005 | 10:28 AM
  #33
BonebrakeJones's Avatar
BonebrakeJones
Wow, new to this forum, wild amount of information here. You guys all rock.. I do have one question tho... Does anyone know of this of SEIC / High Idle mod on an 2003 f350???
Old Oct 25, 2005 | 11:15 AM
  #34
Bear Hunter's Avatar
Bear Hunter
Betaracer...I was hoping you could find out why it would work on my auto and not on your standard
Old Oct 25, 2005 | 12:24 PM
  #35
blakerj10's Avatar
blakerj10
Well Big Ride, your last post worked for me. I used the purple with green tracer. However, my idle does wander like some of the auto guys mentioned. It kind of creeps upward after a while.
Blake
Old Oct 26, 2005 | 09:28 AM
  #36
Scott S's Avatar
Scott S
What kind of resistor do you need for a 6 spd? And where would be the best place to get one?
Old Jan 18, 2006 | 01:22 PM
  #37
cturrisi's Avatar
cturrisi
I would love the part numbers for the new terminals. I found the plug part numbers on your other post about dual processor mod (very impressive). My local parts department is very parts look up handicapped. Also a source to purchase the new terminals would be great.
Thanks,
Chris
Old Jan 22, 2006 | 04:44 PM
  #38
admorris's Avatar
admorris
Just did the high idle on my 06' and it is stumbling, then cutting off. The service light is showing on my dash panel as well.
got any ideas?
Old Jan 22, 2006 | 06:24 PM
  #39
big ride's Avatar
big ride
Thumbs up
No resistors needed, Scott.
svolpone
Apr 8, 2015 01:50 PM
79Supercab
Feb 22, 2015 10:16 PM
mikewrt
Oct 19, 2003 10:49 AM
Ron
Dec 6, 1999 11:39 PM
