Oil & Lubrication
MAnual 5speed trans fluid
Old Dec 27, 2004 | 02:01 PM
99F150's Avatar
99F150
What atf or other fluid is best for our Mazda 5speed trans gears and syncronizers? Max life atf, ordinary atf or synthetic atf or some other man trans fluid?
Iam noticing that with the cold weather my syncro's are a little slow and am planning on changing the fluid. I would like to put in what is best for the trans.
Dan
Old Dec 27, 2004 | 03:29 PM
BrianA's Avatar
BrianA
I have always used the recommended ATF fluid, and paid no particular attention the the brand. Seems like I have Shell ATF in it right now. I change it about every 30-40K miles and it still works fine at 152,000.
I do notice it is a little stiffer when the temp is in the teens, but it always loosens up in a mile or so.
Old Dec 27, 2004 | 04:20 PM
cmlind's Avatar
cmlind
I chose to use Mobil 1 atf for cold shifting since I live in Minnesota. Works great. Even below zero it shifts good. The other alternative that others here like is Red Line. I think it is D4. It is supposed to be even tougher than Mobil 1. I am sure others wil elaborate more on it. Other than cold shifting, I don't think synthetic will give much benefit.
Old Dec 27, 2004 | 04:48 PM
racsan's Avatar
racsan
shoot, i just use off-the-shelf wal mart mercon atf in the gallon jug, change it evry spring, its a little stiff at 10 degrees or less but it frees up with a little time and miles.
Old Dec 27, 2004 | 07:12 PM
wickymustang's Avatar
wickymustang
Anybody got any thing to say about B&M Trick shift, synthetic ATF? Good or bad? Thinking about switching so I can drive in Fargo winters.
Old Dec 27, 2004 | 08:05 PM
TallPaul's Avatar
TallPaul
I believe Trick Shift and the other similar products are Type-F AFTs, that is, they have no friction modifiers for quicker shifing. Not specified for the Mazda 5 speed though (at least not my '95). Should run a Mercon. I have use Mobil 1, but Redline D4 has more antiwear (GL-4 gear lube level without affecting the yellow metal). Called Mobil and they said their ATF probably would be at most a GL-3 if it were even rated that way. GL-3 is roughly half the antiwear of GL-4 so I am told. I have D4 in mine now. Can't say it shifts any better, but may be my tranny, and at least I have the better antiwear.
Old Dec 27, 2004 | 09:37 PM
99F150's Avatar
99F150
Thanks everyone.
I have changed the fluid three times in the three years and 40,000 miles. I bought the truck with 40,000 and now have 80,000. The first time I used Penzoil mercon atf, second was Mobil1 atf and currently has MAx life atf. I plan on changing the fluid again now and am concerned about the sludge buildup on the drain plug each change. That is why I am asking for the best fluid. I have not noticed any difference in shifting from the three differnt fluids.
TallPaul, what fluid are you using that is D4?
Thanks Dan
Old Dec 27, 2004 | 10:00 PM
TallPaul's Avatar
TallPaul
Redline D4. It is "designed to satisfy the requirements of Dextron III, Mercon, and Mercon V, while satisfying GL-4 oil requirements."
Old Dec 28, 2004 | 11:14 AM
99F150's Avatar
99F150
Thanks, I thought we were not to use mercon V though?
Old Dec 28, 2004 | 11:22 AM
jimandmandy's Avatar
jimandmandy
The Mercon V thing only applies to certain automatics, like the E4OD. Type F, without friction modifiers, may help worn syncros. If cold weather is really the issue, go synthetic.
Jim
Old Dec 28, 2004 | 10:57 PM
TallPaul's Avatar
TallPaul
Jim
Yeah. I have a 1990 E4OD and was scared to put the D4 in there so I filled it with Mobil 1 which is a regular Mercon. Working pretty good too.
I did put D4 in the Aerostar's A4LD (1992) and it seems fine.
Old Dec 29, 2004 | 07:54 AM
cmlind's Avatar
cmlind
Don't worry about stuff on the drain plug. The plug is magnetic and catches iron particles. Small metal pieces are normal. If there are large slivers, it may be reason for concern.
Old Dec 29, 2004 | 01:59 PM
Saurian's Avatar
Saurian
How do you all get the ATF back in there into the fill plug? The only time I've ever changed fluid is on my old 89 and I did that with the cover off when I resealed the shiftrail plugs. How do you guys do it?
Old Dec 29, 2004 | 02:46 PM
BrianA's Avatar
BrianA
Hers's how I do it:
https://www.ford-trucks.com/forums/s...d.php?t=204530
very quick and easy.
Old Dec 29, 2004 | 03:17 PM
cmlind's Avatar
cmlind
I put a tipped cap on off a gear oil container and squeeze it in. You can only get about 3/4 of a quart out, but then I pour into another container. Just get an extra quart do do it this way since you cannot get all 4 quarts out.
