hard start when cold
Old Jul 19, 2005 | 12:28 AM
omni's Avatar
omni
would you guys have any clues as to why my 87 302 has a hard time starting when cold, you have to crank it till the starter wants to kick out, but after the first hard start it starts good the rest of the day. when its cold I turn the key till I hear the pump stop then I crank it, so I'm thinking the fuel pressure is there. any ideas where to look. thanks Randy
Old Jul 19, 2005 | 11:19 PM
95X15's Avatar
95X15
Try cycling key on and off several times at cold start to be sure itis primed fully. When was the last fuel filter change?
Old Jul 19, 2005 | 11:36 PM
omni's Avatar
omni
I did the filter about a month ago, with new plugs , cap&rotor, air filter. pcv, then I had ford put in a new maf sensor, oxg senser. and the did a moto vac(flushes all the injectors) do you think its a fuel pressure problem? I turn the key until I hear the pump stop priming, then I try to start it,its like it just doesn't want to fire, I guess its got to be either spark or fuel right, it starts good the rest of the day, thanks for the reply
Old Jul 20, 2005 | 12:18 AM
95X15's Avatar
95X15
Another thought - if you have a lot of moisture in am dew rain etc check cap for sealing /condensation inside. That will cause a lot of problems especially if quality of parts, cap and wires, are questionable. Just some cheap things to try.
Good luvk.
rhoward
Sep 28, 2014 03:55 PM
Randy1229
1983 - 2012 Ranger & B-Series
Mar 13, 2011 12:30 PM
Randy525
Feb 24, 2008 09:14 AM
DEd
Feb 19, 2003 11:04 PM
