Need help.
Old Jul 18, 2005 | 10:15 PM
jandblott's Avatar
jandblott
Need help.
I have a 89 F250 7.3L and have encountered a problem. There is a massive crack on the bracket that holds the clutch pedal, brake pedal, and steering column. It is what seems to be cast aluminum. Does anyone know what this part is called? Is this a common problem with this truck? Is there any way to patch it up without replacing the whole thing (if it is replacable)? Thanks.
Old Jul 19, 2005 | 07:31 PM
nogo73's Avatar
nogo73
Take it to a metal works shop and have them make you a better one. I don't think ford stocks that any more or go to the junk yard.
Old Jul 19, 2005 | 07:41 PM
jandblott's Avatar
jandblott
Actually I went to Ford today and bought the part ($83) and the bushings. It took about three hours to fix and everything is working perfectly again. Thanks for the reply.
Iasphynx
Feb 28, 2013 08:08 PM
BRONCOBITCH94
1978 - 1996 Big Bronco
May 13, 2008 02:12 PM
gchittum
Dec 24, 2006 11:23 PM
Skweeker
General Diesel Discussion
Dec 20, 2005 09:10 AM
