I was using my 92 f-350 DRW to pull a bunch of junk cars yesterday, each of them close to 4-5,000 lbs, plus trailer and crewcab dually, i was close to 15,000 lbs. I noticed on the last car, when pulling out that i could feel a good chatter in the rear end, but i dont have a posi. Brand new u-joints-3 of them on the driveshaft. When I backed up to unload, it was horrible. After unloading i started home with just the trailer, and never felt any chatter or vibration in the truck. I also just changed the gear oil a few months ago with some 85-140. the only chatter/vibration is right when im pulling out at a sharp turn, and loaded down. Is she on her last legs...lol
i would check for slack in the pinion shaft and maybe the steady berring on the drive shaft was the rear end out of oil when you serviced it
good luck
butch
I would think you do have a limited slip axle and LS additive was not added in the gear oil change. Check your door post label for axle info and post it.
I pulled the cover again last night, and for some reason didnt see the clutches in there. there all there beside the spiders, with no additive. i didnt run her too many miles, so i added friction modifier, and ill see how it goes. And to think I work on Fords all day, everday...GEEZ
BTW when I last bought rear end oil, the shop had penzoil with the friction modifier built in. It was quite convient not having to add it seperatly. I was a little concerned that it might not be as good as the standard additive, but its been a couple of thousand miles and so far so good.
