Oil & Lubrication
Slick 50
Old Jul 17, 2005 | 04:55 PM
Bodo's Avatar
Bodo
Slick 50
will this stuff mess up a motor like many other miracle oils, i'm just trying to give my old 79 alittle bit more help. Whats been your results with this stuff. I also heard it has teflon, does that cause any problems with gumming up.
Old Jul 17, 2005 | 05:02 PM
bigdaddyII's Avatar
bigdaddyII
I wouldnt use it. Like many other treatments, it is just a cheap fix for an engine that needs a complete rebuild or is on its last leg.
Old Jul 17, 2005 | 07:52 PM
rusty70f100's Avatar
rusty70f100
This stuff contains PTFE, or Teflon. This is a solid. It can do two things in a modern internal combustion engine:
1. Plug up lifters, causing valve lifter tick.
2. Break down and form acid, not a good thing for metals in your engine.
Any frictional benefits will be offset by the above two negatives. Avoid it.
That said:
What's wrong with your '79 that you were considering using an oil additive? Maybe we can help fix the actual problem, rather than try and cover it up with a band-aid. At the very least, we can suggest far more effective temporary solutions than Slick 50.
Old Jul 17, 2005 | 11:45 PM
250FordTruck's Avatar
250FordTruck
I put it in my '89 mustang when I first bought it at about 20,000 miles. The car has 122,000 miles on it now with absolutely no problems with the engine. So it did no harm.
BUT I have learned that it probably didn't do any good either. Don't waste your money. Save it and fix the real problem.
I also put a lot of RESTORE in an older motorcycle engine. I think that's what it was called. It was supposed to fill in the scratches in the cylinder and make things smooth and brand new again. Don't use that either! It never did a thing for that bike.
But that was when I was new to cars and bike and believed the TV and ads. Then my dad and I rebuilt the bike engine and I started to learn how things really work.
Old Jul 18, 2005 | 01:18 PM
jim henderson's Avatar
jim henderson
Slick 50 is pretty much in the snake oil family from what reading I have done.
There was a research project done by Briggs and Stratton where SLick 50 engines failed sooner than just plain oil engines when run with a dry crankcase.
Dupont, the maker of teflon tried several years back to legally prevent use of teflon in oil since it didin't belong there in their opinion. The courts prevented them form legally stopping it, but I would probably take the advice of a company that stands to make money if you did use their product, when they tell you not to use it.
I have used Slick 50 in several engines over the years. I keep pretty good log books and never noticed any advantages to using Slick 50. With the negative scientific test results versus hearsay, I am no longer using it.
If you look at the advertising, you will not find a real reputable testing lab backing up their claims. All you will get is hearsay from Joe Blow who got 20 more miles per gallon on his clapped out engine. Hearsay is great but in general, the conditions are not controlled so the results are probably luck at best and probably wrong or due to other changes in almost all cases. I have seen variations in some cars I have owned that surprised me but there were no engine or oil changes or anything else I did to explain the mileage difference.
The only additives of use are thickeners and they are only for engines that really need a rebuild but are bandaided to keep from burning oil.
Go with good plain oil. The oil and engine manufactures spend millions of dollars and drive millions of miles to improve and prove their products. You want to pour in some product from a company that doesn't have the testing labs and money to do a thorough test? Not in my engines anymore.
Just my opinion,
Jim Henderson
Old Jul 20, 2005 | 06:00 PM
wavinwayne's Avatar
wavinwayne
FWIW,
Quaker State now sells high mileage oil with Slick 50 already in it. Here's a picture:
Old Jul 20, 2005 | 07:49 PM
76supercab2's Avatar
76supercab2
If it's a solid, wouldn't you think it would get trapped on its first trip through the filter?
Old Jul 21, 2005 | 08:38 PM
jim henderson
Actually that may be a good thing. I hear that over time, if it does make it past the filter, it starts to clog up oil galleries etc.
Best to just use pure fresh quality oil and leave the additives up to the maker. Afterall who knows better than them what is in their oil and what should be in it? Other than apparently Quaker State and I think Pennzoil. I think Pennz owns Slick 50 now don't they? and I know they own Quaker.
Jim Henderson
Old Jul 21, 2005 | 10:08 PM
fordboy_52's Avatar
fordboy_52
we ran slick 50 in our race car, and i had my car up to 280 for a whole race and never saw any prob after that, ill swear by it in my racecar...
Matt
p.s. if your manifolds are glowing red for more than 5 min you know ur a little warm...
Old Jul 22, 2005 | 06:57 AM
wavinwayne's Avatar
wavinwayne
Originally Posted by jim henderson
....I think Pennz owns Slick 50 now don't they? and I know they own Quaker.
Jim Henderson
Copied from penzoil-quakerstate.com
"On On October 1, 2002, the acquisition of Pennzoil-Quaker State Company by Shell Oil Company, an affiliate of the Royal Dutch/Shell Group of Companies, was completed. In May of 2003, Pennzoil-Quaker State Company began doing business as SOPUS Products. Combining Shell lubricant's networks and infrastructure and Pennzoil-Quaker State Company's leading motor oil brands, portfolio of car care brands and Jiffy Lube stores, the new company is a leader in the U.S. lubricants and car care business."
Old Jul 22, 2005 | 12:30 PM
rusty70f100
Another reason I'll never buy QS or Pennzoil, if they're pulling that kind of crap. I wonder what lubrication engineer quit when they came out with oil with Slick 50 in it?
Old Jul 22, 2005 | 09:08 PM
pawpaw's Avatar
pawpaw
Some interesting information on snake oil products & spark plugs.
http://neptune.spacebears.com/cars/legal/index.html
Old Jul 23, 2005 | 12:05 AM
Tomcat7742's Avatar
Tomcat7742
I've been doing a lot of reading on motor oils and oil additives here in the past couple days. I have come to the conclusion that the best thing you can do for your truck is to just change your motor oil every 3,000 miles and stay as far away from additives as possible.
I watched for years as my dad abused his vehicles, letting them go 6 - 7,000 miles between oils changes. He'd run out and buy packedges filled with Slick 50 and Dura Lube, "this is gonna fix the whole problem." Then about a year or two down the road the car is right in the junk yard.
- Chris
Old Jul 23, 2005 | 09:01 AM
superrangerman2002's Avatar
superrangerman2002
Next time you are at your favortie parts house, just take a stroll down the auto chemicals isle.
I bet you'll find that almost 70% of the products are related to Pennzoil/QS (label on the back of the can) in some way, shape, or form. This is especially true when it comes to fuel additives.
Old Jul 23, 2005 | 09:07 AM
pawpaw's Avatar
pawpaw
Yup, & it doesn't give me a warm fuzzy feeling about their other produts either!!!!
