fiberglass topper storage?
I have a fiberglass topper that I want to take off and install a soft tonneau cover. Does anyone have any good ideas on how to store a fiberglass topper? (lay it flat, prop against a wall, build a stand in the garage) was just curious what others did when there not mounted on there trucks. Great forums, THX
As far as storage, the only way I have seen it stored at any cap/cover sellere is like it would be sitting on the truck, not on sides or front/rear. Only thing I can suggest would be to build a rack of some sort that it can lay on. Maybe even hang the rack from your garage ceiling if enough room and assuming you have a garage.
Sort of like I hang my extension ladder in my shed. With chains holding it up.
When I store my wifes hard top for her jeep, I just put down 4 x 4's like it was sitting on the vehicle. I also put a tarp over it to keep it from fading in the sun. I use the 4x4's because I store it in back of the house and have to mow near it. Never have any probs with it.
I used to do the same thing with my other truck, but I didn't store that for long periods of time. Just when I needed to move bigger stuff.
I just bought a used lightweight fiberglass top which had been sitting on a trailer for years, unfastened. It sits just a little wider than it should on my bed, and we wonder if sitting unfastened to anything in the hot sun caused it to spread a little. I had to use a rope with a truckers hitch to pull the sides together enough for the back hatch latches to engage. Then I bolted it in place.
If possible, I'd suggest building a rack that you would bolt the top to, so the sides don't shift or settle/spread.
Thanks for all the info, I did get it off the truck last night (by myself) and it is a bit heavier then I thought! I think I will try hanging it from the rafters in my garage/shed and then either put a strap around or some wooden blocks on each side to keep the sides from bowing out of shape. I may find some help to get it lifted up on my rack though I will send pics once I get it done. THX MoJo
4X4DentSide
12-17-2020 04:27 PM
John R. Thomas
03-29-2014 09:24 PM
LeoJr
15
10-18-2013 08:39 PM
