Bronco II Ford Bronco II
trouble codes
Old Jul 14, 2005 | 10:49 PM
mudbone1979's Avatar
mudbone1979
trouble codes
Hey guys, long time no post, but I am experiencing a problem now that you might be able to help me out with. Here goes:
1) Bad idle
2) No steady fire under load
3) Trouble code is 67, "clutch switch circuit failure" and "neutral Drive Switch circuit open/ac/on"
If anyone could translate that for me that would be awesome, and as always, I really appreciate any timely responses.....
PS '87 BII 2wd
Old Jul 15, 2005 | 07:44 AM
Cootvon's Avatar
Cootvon
is the a.c. on when you ran the test? I know i know.. but i had to ask.. i did the same thing.
Old Jul 15, 2005 | 08:42 AM
mudbone1979
no ac on the truck....i took it off
Old Jul 15, 2005 | 09:25 AM
Cootvon's Avatar
Cootvon
fan was off as well?
Old Jul 15, 2005 | 09:54 AM
mrshorty's Avatar
mrshorty
Assuming that's a KOEO 67, a KOEO 67 is almost always a result of running the KOEO test with the transmission (manual) in gear, and, thus, probably doesn't have anything to do with the bad idle. Repeat the KOEO test, being sure to put the transmission in neutral. If the KOEO 67 isn't resolved, then check the neutral position switch and circuit to make sure it is intact.
Since you don't list any other codes, can I assume that it "passed" the memory portion of the KOEO test? Have you run the KOER test?
This could turn into a case where the EEC-IV computer isn't seeing the problem, and we'll have to work from there.
Old Jul 16, 2005 | 10:05 AM
mudbone1979
no koer yet, but i will checktoday. turns out problem was solved by replacing the dist cap and rotor....
bigmacmondayf250
19
Sep 7, 2014 06:23 PM
Krazymaan
Jun 13, 2011 10:19 PM
qbert
Jun 11, 2010 01:32 PM
Dustball8504
Jan 18, 2009 01:16 PM
