Could I really have 23 P Codes, HELP
Using my Auto Enginuity with ford enhancement I get these codes.
Enhanced Powertrain
P1280 Injector Control Pressure Sensor Circuit Low
P0197 Engine Oil Temperature Sensor Low Input
P0198 Engine Oil Temperature Sensor High Input
P0113 Intake Air Temperature Circuit High Input
P0238 Turbocharger Boost Sensor A Circuit High
P1690 Wastegate Solenoid Circuit
P1395 Glow Plug Monitor Fault (Bank 1)
P1396 Glow Plug Monitor Fault (Bank 2)
P1397 Variable Valve Timing Solenoid B Circuit Low Input
P0380 Glow Plug/Heater Circuit A
P1141 Fuel Restriction Indicator Circuit
P0381 Glow Plug/Heater Indicator Circuit
P1748 Pressure Control Solenoid A
P1536 Parking Brake Switch Circuit
P1464 A/C Demand Out Of Self Test Range
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0220 Throttle / Pedal Position Sensor / Switch B Circuit
P0475 Exhaust Pressure Control Valve
P0232 Fuel Pump Secondary Circuit High
P0460 Fuel Level Sensor A Circuit
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P1212 Injector Control Pressure Lower Than Desired (engine crank or run)
I really only get the P0278 Cylinder 6 injector circuit contribution / balance fault
Which happens to be the injector that is very weak when doing the buzz test. I guess I need a new injector.
Hopefully that will make my engine smooth out and quit poofing white smoke up my breather tube. Not to mention the tail pipe.
Thank god its on the drivers side. I wonder if i should take out that AE that's in #8 and put in an AD because it doesn't buzz quite as loud either. Unless there is a difference in AD and AE buzz noises. I wouldn't have a clue.
Its still very sluggish when i give it "gas" while parked and hurles out white smoke when the rpms rise.
On the last note. My Van just died flat out last week in my driveway and I went to ford and put in a gray tps. I went to a auto store here called Rooster, lol. But they can get the black tps for the 95 to 96 powerstroke. Isn't that the "good" one that we all want?
thanks for the resetting the pcm tip. much appreciated.
What do you mean puffing smoke out the breather tube? Is it just smoke or is there pressure behind it? Smoke is fine, pressure is bad.
You could always swap the #4 and #6 injector to make sure the problem followed the injector instead of staying in the same hole before you dumped the money for a new injector. The AE should buzz just as loud as the AD injectors.
Yep I believe there is pressure behind the puffs of smoke. I would consider the amount of smoke to be medium to alot of smoke myself, like a small locomotive steam train. plus enough to throw the smoke about a foot from the valve cover without alot of pressure behind it. My kid started my van up every day for two months this winter with starting fluid. Yep, Idiot comes to my mind too. I did'nt know this until he told me that "we" need another can.
As much as I don't want too, I think i will change those two injectors around to make sure its not the wiring. Your right, its expensive.
I still get that dam P0278 & 81 Cylinder 6 and 7 injector circuit contribution / balance fault
Everyone says what it is but nobody gives a good explanation on what it means. bad connection? low voltage? fuel pressure? I cant figure out what balance fault really means. Any ideas?
Sounds like a compression test is your next step. You may have one or more bad cylinders.
Its a 2001 14' box van. works and looks terrific except engine. I am a Contractor. I need a Box Van. I have to decide if its worth buying a new engine for 5k ( I will install) or another used box van with 150k+ miles on it for 5k.
So I am going to put a 5k engine in a box van thats only worth 5k? Then have a perfect box van. Hmmm probably
Or trash this van, buy another one for 5K, with at least 150+K miles on it and hope it lasts a long time with my fingers crossed. While having another used engine that could go wrong.
I think my money might be on an engine r and r.
Any educated thoughts?
Kind of depends on what that other box van has going on with it.
Need to get it checked out thoroughly before making any sort of decisions.
