Power steering pump bracket for 302
Old Dec 19, 2002 | 08:10 AM
denise's Avatar
denise
[updated:LAST EDITED ON 19-Dec-02 AT 09:26 AM (EST)]Hi we are in the process of putting a 302 in a 79 1/2 ton 4WD shortbox pickup. Has anyone ever done this kind of a swap and if so what did you do for the power steering pump bracket. Am I right in assuming that Ford didn't put 302's in 4WD's in 78 or 79. What about Bronco's could you buy a 79 with a 302 in it? Thanks
Old Dec 19, 2002 | 10:33 AM
theonlybull's Avatar
theonlybull
try using a bracket and pump off a 80's ford truck/car that's what's on mine
Old Dec 19, 2002 | 06:15 PM
0u812's Avatar
0u812
Post Power steering pump bracket for 302
I,m in the process of swapping a 302 in to my 78 F 150 4x4 swb. pickup. Ford used the 302 in there late 70,s 2wd's and 351/ 400m's in there 4wd's. I got my motor from a 78 2wd . I also have a F 250 so I decided to go with a more economic engine for the F150. Two wheel drive motor parts will work for your 302. I had the pump but was missing the mounting bracket. When I went to find this part I learned (the hard way) that in 78 they went from early style to late style pump and mount in mid year, this is something you will want to watch out for! Good luck on your project!
Old Dec 19, 2002 | 07:57 PM
Mil1ion's Avatar
Mil1ion
Old Dec 8, 2023 | 07:04 PM
Ed70's Avatar
Ed70
2nd Gear
Power steering bracket for a 78 302 2wd 150
Can you show me the bracket that you ended up using.
Old Dec 9, 2023 | 12:06 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
21 years later I will be surprised if Denise still even owns the truck. His last interaction with FTE was 12-19-2002. 3 posts only. Ou812 has not been on here since 12-30-2002 so I doubt he will see your question either. Always check the date of the last post or reply to a thread before you post up. Just make a new thread and tell us what you are working on and trying to do. Obviously locate a 302 power steering pump bracket, or add p/s to a 302. The PDF attachment might help.
File Type: pdf
Old Dec 9, 2023 | 09:12 AM
Viper Pilot's Avatar
Viper Pilot
Check this out, and then let this thread die. It seems like it was useless to begin with anyway
https://www.cvfracing.com/ford/ford-...belt-brackets/
Old Dec 9, 2023 | 09:49 AM
Ed70's Avatar
Ed70
2nd Gear
The problem is it shows all the brackets which I found from this same company. But none of them show you the pump that they actually go to.
I could buy twenty different brackets, but it doesn't tell me that it's gonna go with the pump that I currently have.
Old Dec 9, 2023 | 10:06 AM
Viper Pilot
Call CVF on Monday. They’re very helpful. Also, start a new thread.
msalander
21
Jul 26, 2023 11:59 PM
msalander
Nov 14, 2022 04:38 PM
BigBlueCat
Dec 29, 2016 02:12 PM
55forder
Mar 28, 2005 08:31 PM
